Does someone see this message on Nios console ?? *** uCOS init, can't create global_wakeup_Mutex = 40 dtrap - needs breakpoint In my configuration I'm using uCos+Iniche Stack RegardsLink Copied
The 'dtrap - needs breakpoint' has been mentioned before.
It is basically a 'panic' - with a hint to use a debugger breakpoint in order to get more info.
