Hello!
Just a simple question: does the Nios2 toolchains supports the XIP (Execute in place) execution mode ? I've checked the flags of flat binaries and are all set to FLAT_FLAG_RAM. I'm trying to port php to a nios2 platform. I've successfully built it, but when i try to run it i get a "memory exhaust" message. The exec file size is about 1Mb. So it would be better to run it in flash memory instead of ram. Any idea ? Thanks in advance. Gabriele Brugnoni gabriele.brugnoni@dveprojects.comLink Copied
Currently the Nios II toolchain does not support PIC (position independent code), and as a result, XIP is not available for Nios II.
