about flash2dat
Hello I'm suyo.
I hava a question about flash2dat utility.
flash2dat executes the following command.
flash2dat --infile=ext_flash.flash --outfile=ext_flash.dat --width=8|16|32|64|128 --base=0x0 --end=0xFFF --pad=1 --create-lines=1
Which address will the base address and the end address should set?
Design is using standard.
Regars,
suyo
