12608 Discussions
altera 11 usbblaster ubuntu 11.04
Hello all,
I am running into the dreaded ubuntu usbblaster issue. I am on ubuntu 11.04 32 bits with Altera 11 (which is supposed to be better). I got this to work using altera 10 with earlier ubuntu, but no cigar with the current permutation. Any hints on how one might fault isolate this issue are appreciated.
$ jtagconfig
1) USB-Blaster [2-4]
020F30DD
And nios2-download always gives this error.
"There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary."
I do repeated download a new SOF file with the reference design from altera (and that completes w/o errors), and also use the power up reset reference design w/o any success.
I have this in my /etc/udev/rules.d/40-altera-usbblaster.rules (I tried some the other variations being passed around on the web and they dont appear to work complaining that there isn't sufficient privilege to access the port)
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster", GROUP="plugdev"
$ ls -l /dev/usbblaster
lrwxrwxrwx 1 root root 15 2011-09-26 15:24 /dev/usbblaster -> bus/usb/002/009
$ ls -l /dev/bus/usb/002/009
crw-rw-r-- 1 root plugdev 189, 136 2011-09-26 15:35 /dev/bus/usb/002/009
$ lsusb -d 09fb:6001 -v
Bus 002 Device 009: ID 09fb:6001 Altera
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x09fb Altera
idProduct 0x6001
bcdDevice 4.00
iManufacturer 1 Altera
iProduct 2 USB-Blaster
iSerial 3 91d28408
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 150mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 USB-Blaster
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
So in summary, I can program the device with the reference design, but somehow I am unable to download software.
$ nios2-configure-sof niosii_ethernet_standard_3c25.sof
Searching for SOF file:
in .
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag -o p;./niosii_ethernet_standard_3c25.sof
Info: Using programming cable "USB-Blaster [2-4]"
Info: Using programming file ./niosii_ethernet_standard_3c25.sof with checksum 0x00CC2B53 for device EP3C25F324@1
Info: Started Programmer operation at Mon Sep 26 16:28:37 2011
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020F30DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Mon Sep 26 16:28:38 2011
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 94 megabytes
Info: Processing ended: Mon Sep 26 16:28:38 2011
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:00
$ make
Info: Building ../../bsp/hal_default/
make --no-print-directory -C ../../bsp/hal_default/
[BSP build complete]
[hello_world build complete]
$ nios2-download hello_world.elf
I did try some of the other solutions suggested on this forum
$ cat /etc/udev/rules.d/40-altera-usbblaster.rules
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
$ sudo udevadm control --reload-rules
$ jtagconfig
020F30DD
$ /home/hill/altera/11.0/nios2eds/nios2_command_shell.sh
Altera Nios2 Command Shell [GCC 4]
Version 11.0, Build 157
$ jtagconfig
020F30DD
OK, found the solution (on the wiki)!
$ sudo mkdir /etc/jtagd
$ sudo cp /home/hill/altera/11.0/quartus/linux/pgm_parts.txt /etc/jtagd/jtagd.pgm_parts
$ ls /etc/jtagd
jtagd.pgm_parts
$ jtagconfig
020F30DD
$ killall jtagd
$ jtagd
$ jtagconfig
020F30DD EP3C25/EP4CE22
Using cable "USB-Blaster [2-4]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 49KB in 2.7s (18.1KB/s)
Verified OK
Leaving target processor paused
success!
Thanks for posting your results..
Just wanted to say thanks to JeffreyOHill as well. His solution worked for me. Much appreciated.
For what it's worth, this also worked for me on machine where I just did a fresh install of Ubuntu 12.04 (not an update).
JefferyOHill, thanks for such a comprehensive report. May you live to be a thousand years old.
