Hi people
I have made the standard hello world as a test app for my custom board. Makefileinclude Rules.mak
ECLIPSE_WORKSPACE := /cygdrive/c/altera/kits/nios2/bin/eclipse/workspace
KERNEL_PROJECT := hello_world
BUILDDIR := $(ECLIPSE_WORKSPACE)/$(KERNEL_PROJECT)/build/include
CFLAGS += -O0 -g -I$(BUILDDIR)
all: hello.exe hello.gdb
Rules.mak is the standard file and has not been modified. When I try to compile the code shown here below the error below the code is shown. Code: hello.cpp #include "stdio.h"
int main(int argc, char *argv)
printf("Hello world test app!!!\n");
return 1;
console : compiler/linker make -k all
no emulation specific options.
nios2-elf-gcc -nostdinc -D__linux__ -O2 -I"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -O0 -g -I/cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/hello_world/build/include -Wall -o hello.o hello.cpp
nios2-elf-gcc -r -d -L"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o hello.bin hello.o /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a
hello.o(.text+0x0): In function `_start':
: multiple definition of `_start'
/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/crt0.o(.text+0x0): first defined here
collect2: ld returned 1 exit status
make: *** Error 1
make: Target `all' not remade because of errors.
Hope some of you can tell me what I am missing here. thx upfront. Regards Michael E
Hi
Just an update 1) have changed my makefile to the one shown below# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 1
PROJ_NAME = hello
INSTALL_DIR =
PROGS := $(PROJ_NAME).exe
CFLAGS +=
# # You should not need to modify anything beyond this point# # TOPDIR = ..
include Rules.mak
ifeq '$(DEBUG)' '1'
PROGS += $(PROGS:.exe=.gdb)
endif
all: $(PROGS)
.PHONY: clean
clean:
-rm -f *. *.elf *.gdb *.bin *.exe
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
2) I have compiled a custom uClibc library ( used the guide for this ) 3) Have tried overwriting the lib folder with the new files created by my custom compilation. c:\altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0\lib has been replaced by the files from C:\altera\kits\nios2\examples\software\linux\ECTKernel\lib Still I get the console output <div class='quotetop'>QUOTE </div> --- Quote Start --- make -k all no emulation specific options. nios2-elf-gcc -nostdinc -D__linux__ -O0 -g -I"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall -o hello.o hello.cpp nios2-elf-gcc -msys-crt0="c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/crt0.o -r -d -L"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o hello.bin hello.o /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a hello.o(.text+0x0): In function `_start': : multiple definition of `_start' c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/lib/crt0.o(.text+0x0): first defined here collect2: ld returned 1 exit status make: *** [hello.bin] Error 1 make: Target `all' not remade because of errors. rm hello.o[/b] --- Quote End --- sugestions??? Regards Michael E
Why not hello.c instead of hello.cpp?
I test when *.c change to *.cpp, the same error occurs. So in my opinion, if you insist to *.cpp you should add some proper FLAG to tell compiler to compile *.cpp.- Mark as New
Hi mountain
Thx dude. That was it. Changed to .c now it compiles http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif ) Regards Michael E
