12612 Discussions
how to write a costum gpio interrupt driver
I want to write a custom gpio interrupt driver. I just want to trigger the led in interrup handle function.
In my probe function I register interrupt and initial the registers.
I can see the interrupt number in /proc/interrupt after booting.
Like below
197: 0 0 GIC gpio_key
but the interrupt handle function nerver execute.
What is the problem with the driver?
Thanks in advance.
I'm having trouble compiling my custom device driver. I'm using the 14.1 tools.
My compiled linux is in /home/user1/linux-socfpga
My cross compiler is in /home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf-
My device driver is in /home/user1/newDriver
I'VE TRIED LOTS OF THINGS - and googled for a few hours
One was -- from the newDriver directory I tried:
# ] make ARCH=arm CROSS_COMPILE=/home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf- KERNEL_SRC=/home/user1/linux-socfpga
IT TRIES BUT CAN'T FIND the kernel header files.
Any help would be greatly appreicated.
--- Quote Start ---
Thanks in advance.
One was -- from the newDriver directory I tried:# ] make ARCH=arm CROSS_COMPILE=/home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf- KERNEL_SRC=/home/user1/linux-socfpga
--- Quote End ---
SOLUTION: Here is the Makefile
KERNEL_DIR=/home/user1/linux-socfpga
obj-m := testDriver.o
PWD := $(shell pwd)
default:
$(MAKE) M=$(PWD) ARCH=arm CROSS_COMPILE=/home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf- -C $(KERNEL_DIR) SUBDIRS=$(PWD) modules
clean:
$(MAKE) -C $(KERNEL_DIR) SUBDIRS=$(PWD) clean
Hey jpe1313,
Can you please specify what is the content of your linux-socfpga?
Is this :
http://git.rocketboards.org/linux-socfpga.git
Yes, it is. There are instructions on how to get your Linux release and tools.
http://www.rocketboards.org/foswiki/documentation/gsrd141compilinglinux
and if you want to checkout a different kernel follow these instructions -->
http://rocketboards.org/foswiki/documentation/alterasocltsirtkernel
Hope that helps.
