12610 Discussions
nios crash,but I don't know what the reason is
hi
i'm trying to use the nios and some other FPGA logic to achieve composing some inputs to a display,
now it running right most of the time,but sometimes when startup or running for a long time ,it can't run, I found that the FPGA logic is still running but only the nios is crashed, the reset I think is OK and I can't find any reason to explain it and resolve it.
so any one can help me
thank U ~!
Maybe your soft has a memory leak, a blocking routine, an overflow, a blocking mutex, a priority inversion...
Do you use superloop or an OS like ucOS, FreeRTOS, ecos, uclinux ?
Could you describe your soft ?
Which components do you use ?
We have not enough information in order to answer.
superloop,I'don't know the details, I just do the part of FPGA logic,soft is done by others
