platform_get_resource fails
Added a custom device driver to GSRD 14.1
The IP is contained in sopc0: hps_0_bridges: bridge@0xc0000000
of_match_device - is successful -
Looking in my: /proc/device-tree/sopc@0/bridge@0xc0000000/serial@0x100040000
When I do # ] hexdump -C 'compatible'
I can see my entries that match with the of_match [] of the device driver
When I do# ] hexdum -C 'reg'
I see the values in my dev entry
BUT, the platform_get_resource fails.
--- Quote Start ---
--- Quote End ---
I had a line missing in my .dts file so I generated another .dtb file and now the driver loads. STILL HAVE A PROBELM - when I use the driver I should see activity on a couple of the Cyclone V Dev kit board HSMC - but the lines aren't toggling. So - WHAT AM I MISSING? I have: 1. generated the .dtb, .rbf and added them to the microSD card. I have cross compiled my device driver and put it on the microSD card and simply done an "insmod myDriver.ko" - I saw that maybe I needed a new preloader image so I created a new on of those.
REALLY NEED SOME HELP:
1. We put our IP on the FPGA-HPS bridge that the leds are on.
2. Got/generated all the files via instructions - .rbf, .dtb (and I wasn't sure so did do the preloader-mkpimage.bin)
I did have to generate a new device tree
2b. I had to update the zImage because the version magic numbers did not match -- when I did this the led-gpio driver gives the message:
platform leds.1: Driver leds-gpio request probe deferral -- why?
3. I DID NOT add the driver to the kernel but just cross compiled it and put it on the sd card to manually insert.
When I insert the device driver - I get an error with the: of_address_to_resource
static int touchscreen_drv_probe( struct platform_dev *op)
int rc = 0;
struct device_node *node = op->dev.of_node;
struct resource res;
// the of_match_device works ---
rc = (of_address_to_resource( &op->dev.of_node, 0, &res);
if (rc)
//fail
Where could the disconnect be?
SOLVED -- used "platform_get_resource" and all is well. Not sure why the "of_address_to _resource" did not work but my device driver works fine.
