12609 Discussions
port goahead web server to nios2 uclinux
hi all:
I ported goahead websrver to nio2 use hippo's toolschain.
GoAhead WebServer 2.1 is a fully-featured, open-source embedded Web server that leverages Active Server Pages, embedded JavaScript, and in-process CGI forms processing (GoForms™) to deliver highly efficient and effective dynamic web page creation. Its source code is available free on the GoAhead website (http://www.goahead.com/webserver/wsregister.htm) to developers without royalties or proprietary lock-ins and is subject to the terms specified in the GoAhead .
The following step is my process:
1)download goahead webserver source code(webs218.tar.gz) from internet.
2)tar xzvf webs218.tar.gz
3)in the ../ws031202/LINUX dir,rework the original Makefile.
The original Make file is follow: attached
4)edit misc.c in the ../ws031202 dir
commet follow code:
//static int strnlen(char_t *s, unsigned int n);
* Return the length of a string limited by a given length
// unsigned int len;
// len = gstrlen(s);
// return min(len, n);
5)open the terminal ,cd ../ws031202/LINUX dir
6) PATH=$PATH:~/buildroot/build_nio2/staging_dir/bin
7)make
8)cp webs to ../rootfs/bin,cp ../ws031202/web dir to ../rootfs
9)rebuild kernel for inramfs use command "make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-"
10)nios2-linux-uclibc-strip vmlinux
11) under nios sdk shell,use command "nio2-download -g vmlinux" to download the vmlinux to your target board
12)open the windows terminal,cd /bin
13) exec command "hostname localhost"
14) exec command "webs"
now your goahead webserver is running on your target board.you can open your IE,then type your target board IP to visit the demo HTML.
ps: because I am a linux beginner.So my rework Makefile maybe have some bugs.if anyone find any mistakes,please tell me right here. Thanks.
Hi Alex,
Good work.
Please try out the new kernel. And let me know.
You can use subversion to help tracking your works.
Try "which svn", if you don't have it, install it with "yum install subversion". (for fedora core)
1. create the svn store, and check your original as rev1.
cd ~ mkdir mysvn svnadmin create mysvn/webs tar xzvf webs218.tar.gz svn import ws031202 file:///home/alex/mysvn/webs/ws031202 -m="initial" rm -rf ws031202 svn co file:///home/alex/mysvn/webs/ws031202
2. make your change to Makefile, misc.c ....
build and test....
3. after you finished, or when you want to save your change to store, as rev2
cd ws031202 svn commit -m="update for nios2 uclinux" svn diff -r1:2 >webs.diff
Then you can send webs.diff to others
4. when other get your diff file, he can apply the patch and get the same update from yours.
tar xzvf webs218.tar.gz cd ws031202 patch -p0 <webs.diff
The subversion is very helpful. You can find more usages from the subversion guide on their web.
Hi hippo:
Thank you for suggestion.
I have completed the diff file.
Can you tell me how to upload attached file in the forum?
Great.
You can attach files in the "post your ip" area. Or you can add your diff file in line here.
the goahead webserver diff:
Index: LINUX/Makefile
--- LINUX/Makefile &#65288;&#20462;&#35746;&#29256; 1&#65289;
+++ LINUX/Makefile &#65288;&#20462;&#35746;&#29256; 2&#65289;
@@ -9,6 +9,11 @@
all: compile
+CC = nios2-linux-uclibc-gcc
+AR = nios2-linux-uclibc-ar
+LD = nios2-linux-uclibc-ld
+OBJCOPY = nios2-linux-uclibc-objcopy
ARCH = libwebs.a
NAME = webs
@@ -56,11 +61,11 @@
../security.o ../sym.o ../uemf.o ../url.o ../value.o
../md5c.o ../um.o ../umui.o ../websda.o ../emfdb.o
../webrom.o ../webs.o ../websuemf.o main.o
-CFLAGS = -DWEBS -DUEMF -DOS="LINUX" -DLINUX $(UMSW) $(DASW) $(SSLSW) $(IFMODSW)
+CFLAGS = -DWEBS -DUEMF -DOS="LINUX" -DLINUX -Dfork=vfork -D__uClinux__ $(UMSW) $(DASW) $(SSLSW) $(IFMODSW)
OTHERS = -DB_STATS -DB_FILL -DDEBUG
DEBUG = -g -Wall
IFLAGS = -I..
-LDFLAGS = $(SSLLIB) $(IFMODLIB)
+LDFLAGS = $(SSLLIB) $(IFMODLIB) -elf2flt="-s 64000" -Wl,-v -Wl,-d
compile: $(NAME)
@@ -75,7 +80,7 @@
$(NAME): Makefile $(ARCH)
$(CC) -o $(NAME) $(DEBUG)
- $(CFLAGS) $(IFLAGS)
+ $(CFLAGS)
main.o $(ARCH) $(LDFLAGS)
clean:
@@ -152,4 +157,4 @@
# Transition rules (add -o to put object in right directory)
.c.o:
- cc -c -o $@ $(DEBUG) $(CFLAGS) $(IFLAGS) $<
+ $(CC) -c -o $@ $(DEBUG) $(CFLAGS) $(IFLAGS) $<
Index: misc.c
--- misc.c &#65288;&#20462;&#35746;&#29256; 1&#65289;
+++ misc.c &#65288;&#20462;&#35746;&#29256; 2&#65289;
@@ -58,7 +58,7 @@
static int dsnprintf(char_t **s, int size, char_t *fmt, va_list arg,
int msize);
-static int strnlen(char_t *s, unsigned int n);
+//static int strnlen(char_t *s, unsigned int n);
static void put_char(strbuf_t *buf, char_t c);
static void put_string(strbuf_t *buf, char_t *s, int len,
int width, int prec, enum flag f);
@@ -425,13 +425,13 @@
- unsigned int len;
+// unsigned int len;
- len = gstrlen(s);
- return min(len, n);
+// len = gstrlen(s);
+// return min(len, n);
hi:
I got a applet.diff for gahead webs.
I run svn diff -r1:2 >webs.diff
But not success complete.How can I solve it? Thanks.
[alex@localhost ws031202]$ patch -p0 <applet.diff
(Stripping trailing CRs from patch.)
patching file webs.h
Hunk# 1 FAILED at 85.
1 out of 1 hunk FAILED -- saving rejects to file webs.h.rej
patching file webs.c
Hunk# 1 succeeded at 22 with fuzz 1.
Hunk# 2 FAILED at 258.
Hunk# 3 FAILED at 280.
patch unexpectedly ends in middle of line
Hunk# 4 FAILED at 1161.
3 out of 4 hunks FAILED -- saving rejects to file webs.c.rej
Where do you get the applet.diff?
--- Quote Start ---
originally posted by hippo@Mar 2 2006, 09:42 PM
where do you get the applet.diff?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13088)
--- quote end ---
--- Quote End ---
I got the diff in a goahead bbs as follow:
http://www.prolix.ro/dokuwiki/documentatio...et_does_not_run (http://www.prolix.ro/dokuwiki/documentation:goahead:general#java_applet_does_not_run
I copy the lines to blank text file,then I rename the file is *.diff
They failed in white space, because we cut them from web page.
Use "-l" option in patch to ignore white space.
Remove the old ws031202 dir, untar again, then apply patch,
patch -l -p0 <applet.diff
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
I ported goahead websrver to nio2 use hippo&#39;s toolschain.[/b]
--- Quote End ---
can you help in doing the same but under the IDE ?
Warm Regards
--- Quote Start ---
originally posted by mfm@Apr 5 2006, 02:05 PM
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
i ported goahead websrver to nio2 use hippo&#39;s toolschain.
--- Quote End ---
Warm Regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14072)</div>
[/b]
--- Quote End ---
Hi MFM:
If you want to use goahead webserver in nios2 linux, you must use toolchains cross compile it. The IDE is difficult to compile it. I think the best way is build your nios2 toolchains under linux.
hi alex, i followed ur steps to port the webserver. everything seems fine but i cant access the demo webpage. i can ping my de2 but cant access it with web browser.
here are some of my questions:
1. must i follow the Buildrootguide to build the toolchain? i&#39;m totally new and i used the BinaryToolchain for newbies.
2. step 9: shud i run that cmd under ~/ws031202/LINUX dir or under ~/uClinux-dist-test/ dir? is it this cmd is suppose to replace the &#39;make linux image&#39; as in uClinuxDist?
3. step 10: whr shud i run this cmd? i tried the vmlinux file under ~/uClinux-dist-test/linux-2.6.xx/ (<= sry cant remember the numbers...) is it correct?
Pls help. thank you in advance.
ps. i&#39;m totally new n i hope my q doesnt sound stupid. i&#39;ll b glad if u would like to suggest anything.
Hi alex,I followed your steps to port the webserver.When I arrived the 10) step,I met the following err:
[w@localhost w]$ cd uClinux-dist-test
[w@localhost uClinux-dist-test]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-
uclibc-
make -C tools/ucfront
make[1]: Entering directory `/home/w/uClinux-dist-test/tools/ucfront&#39;
make[1]: Nothing to be done for `all&#39;.
make[1]: Leaving directory `/home/w/uClinux-dist-test/tools/ucfront&#39;
[ -d /home/w/uClinux-dist-test/images ] || mkdir -p /home/w/uClinux-dist-test/im
ages
cp /home/w/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/boot/zImage /home/w/uCl
inux-dist-test/images/zImage
make[2]: Leaving directory `/home/w/uClinux-dist-test/vendors/Altera/nios2nommu&#39;
make[1]: Leaving directory `/home/w/uClinux-dist-test/vendors&#39;
[w@localhost uClinux-dist-test]$ nios2-linux-uclibc-strip vmlinux
nios2-linux-uclibc-strip: &#39;vmlinux&#39;: No such file
Then I do it by the following way,but I do not know if it is correct.Could you tell me what does the command "nios2-linux-uclibc-strip" mean?
[w@localhost uClinux-dist-test]$ nios2-linux-uclibc-strip images/zImage
hi all:
i follow Alex&#39;s work and complete. Could you teach me how to add IP in goahead?......thank all!.... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Hi All,
I am trying to port Go Ahead into REX OS for Qualcomm Mobile phones. Can I follow same steps for that OS too?
I have tried the normal porting methods, but getting thousands of errors. Since I am new to this, expecting your support.
For those trying to access current releases of the Goahead-Webserver, it is now being hosted by Embedthis Software at: embedthis.com under products.
