serial port as std i/o
Hi all,
when i have two nios processors in my system
one connected to the jtag uart(console) and the
other to the serial port(hyper terminal), when i debug the processor
the printf statements are getting printed in partial
for example if i printf("this is the cpu")
it is printing like "this" first and after debug of several statements
it is printing the remaining like "this is"
and then after some more debugging "this is the"
and then after so many the complete statement as"this is the cpu"
can anybody guess the reason?
thanks and regards
prasad
It's possible that it's just a matter of flushing the output. Do you have a \n at the end of your debug string? Sometimes that alone does the trick. If not, you can add fflush(stdout) after the printf that you want to see immediately.
Andrew
It could be a matter of having the string sent by printf, but still in the buffer of the peripheral...
However the fact you are using 2 Nios II should not have influence on this behavior...
bye
Paolo
Hi thanks for the response also
i would like to clarify myself
regarding the following.
in the same two processor system
if i attach serial port as std i/o tothe first
processor(as per alphabetical order) and the other
processor to jtag uart, if i run it is doing this
by printing on the console as
"can't open uart : permission denied"
and then it stops
what could be the reason?
also i observe that it launches in the alphabetical order.
please do comment on this.
regards
prasad
