unstable-nios2mmu boot error
Hi all,
Here is what I try to do :
When I try to make my Linux boot I got the following :
fault during kernel misaligned fixup @ 0xd0212794; addr 0x00000003; isn=0x20800017
Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2) #21 Thu May 12 14:31:53 CEST 2011
bootconsole [early0] enabled
early_console initialized at 0xe4842020
On node 0 totalpages: 4096
free_area_init_node: node 0, pgdat d04d66a8, node_mem_map d04f1800
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
Kernel command line:
PID hash table entries: 64 (order: -4, 256 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 11144k/5039k RAM (2107k kernel code, 2932k data)
NR_IRQS:32
Unable to handle kernel NULL pointer dereference at virtual address 00000000
ea = d0212b98, ra = d0212b98, cause = 14
Kernel panic - not syncing: Oops
I don't know where is the issue (hardware design, kernel, erroneous device-tree).
Maybe that comes from the first "error" I get : fault during kernel misaligned fixup @ 0xd0212794; addr 0x00000003;
Does someone has any idea ?
Best regards
See attached for the device tree
My nios.h (you still need to modify it) :
Code:
#ifndef _ASM_NIOS2_NIOS_H
#define _ASM_NIOS2_NIOS_H
/* Add some defines wich should REALLY be extracted from fdt */
/* ==> REMOVE */
#define DDR2_TOP_BASE 0x10000000
#define DDR2_TOP_SPAN 16777216
/* <== END REMOVE */
* Maximum possible cache sizes on the Nios II. Only used in head.S where
* the information from cpuinfo is not yet available.
#define NIOS2_DCACHE_SIZE 2048
#define NIOS2_ICACHE_SIZE 4096
* Minumum possible cache line sizes on the Nios II. Only used in head.S
* where the information from cpuinfo is not yet available.
#define NIOS2_DCACHE_LINE_SIZE 32
/* Nios II instruction cache line size is always 32 bytes */
#define NIOS2_ICACHE_LINE_SIZE 32
#define NIOS2_ICACHE_LINE_SHIFT 5
#endif /* _ASM_NIOS2_NIOS_H */
I found the issue. In fact the device-tree generator (sopc2dts : from .sopcinfo to .dts) does not support the version 10.1 of the timer. So I manually modify the timer description in the .dts. But I forgot to add the clock-frequency value, so I got a "NULL pointer error".
The timer description should be :
--- Quote Start ---
//Port data_master of cpu_0
timer_0: timer@0x4842000 {
compatible = "altr,timer-8.0";
reg = < 0x4842000 0x20>;
interrupt-parent = < &cpu_0 >;
clock-frequency = <50000000>;
interrupts = < 0 >;
}; //end unknown (timer_0)
--- Quote End ---
Now I get another issue in the boot process :
--- Quote Start ---
fault during kernel misaligned fixup @ 0xd02157b0; addr 0x00000003; isn=0x20800017
Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2)# 64 Fri May 13 10:56:50 CEST 2011
free_area_init_node: node 0, pgdat d04b2814, node_mem_map d04cd800
DMA zone: 36 pages used for memmap
DMA zone: 4060 pages, LIFO batch:0
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4060
Memory available: 11272k/4895k RAM (2119k kernel code, 2776k data)
NR_IRQS:32
late time init = d0215b28
Calibrating delay loop... 22.88 BogoMIPS (lpj=45760)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
pcpu-alloc: [0] 0
NR_IRQS:32
Calibrating delay loop... 22.97 BogoMIPS (lpj=45952)
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
Switching to clocksource timer
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
IPv4 FIB: Using LC-trie version 0.409
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
[few second to wait here]
JFFS2 version 2.2. (NAND) &#65533;© 2001-2006 Red Hat, Inc.
msgmni has been set to 22
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
ttyAL0 at MMIO 0x4842020 (irq = 2) is a Altera UART
console [ttyAL0] enabled, bootconsole disabled
dm9000 Ethernet Driver, V1.31
TCP cubic registered
NET: Registered protocol family 17
Oops: Exception in kernel mode, sig: 4
r1: d0c1c000 r2: 00000b0e r3: d0221000 r4: 00000000
r5: 00000000 r6: 00000000 r7: ffffff80 r8: d04d2240
r9: 00000218 r10: d04b28e4 r11: d04d2360 r12: d04d2248
r13: 00000003 r14: ffffffff r15: 00000001
ra: d021647c fp: fffffbff sp: d0c1ded4 gp: 00000000
ea: d0216484 estatus: 00000001
Kernel panic - not syncing: Attempted to kill init!
--- Quote End ---
I will give you feed back if I found this issue
Best regards
Hi zben,
Did you succed to boot the kernel since you posted your message?
I try to use the unstable-nios2mmu branch to use the device tree, but I have a problem. I can't find any linux-2.6/arch/nios2/boards/generic-dts/include/asm/nios.h path to modify the nios.h file....
Did you add this file or it was included in the unstable-nios2mmu branch ?
With the support of device tree, did you tape only "make" in uClinuxDistr or "make path_to_device_tree.dts" in order to compile the kernel?
Thank you for your help.
Best regards.
Pierre
Yes I succeed to make it boot, the issues :
- I update the kernel to a too new version
- Same problem to the uClinux-dist directory
so get the latest nios2-linux, then checkout but don't update
For the nios.h I'm not sure to remember (I delete my project) but I think it was in arch/nios2/include/nios.h
I compile using only make, the .dts to use is set in the .config of the kernel
Best regards
PS: If I remember well I have other errors after boot (like no network on the board or something like that, so I decide to wait for this branch be more mature and I return back to the trunk). I explain it in a post but Altera moderator block it...
It's a bit late, but I have possibly found a bug that may provokes this 'fault during kernel misaligned fixup'.
It happens when CONFIG_PASS_CMD_LINE is not set under menuconfig (because the parameter passed to early_init_devtree() is not initialized to be more precise).
However, it has no relationship with the kernel panic that comes later...
