voltage I/O & system timer
I have two questions : I don't know why calling alt_timerstamp_start() generates ticks count at 50 MHz. Although I initialized the Timestamp timer (HIGH_RES_TIMER) at 1ms/tick in SOPC Builder. I thought that the tick count could be incremented at each 1ms interval.
My second question is about the I/O voltage. I'm using Stratix 1S10 dev. board and I can use the prototype header to test a small design. I would like to send TTL (0-5V) voltage to the dev. board but I don't which IO to choose.
Best regards
Christian
According to this http://www.altera.com/literature/hb/stx/ch_4_vol_2.pdf (http://www.altera.com/literature/hb/stx/ch_4_vol_2.pdf) you may need to convert to a 3.3/1.8 level (use external logic to do this).
