hi,
i,ve successfully run the web server program on nios II,and i've modified the ro_zipfs contents,then after building the program and running,and then typing http://ip (http://ip) addr,i get the file which is in the ro_zipfs.zip,but after programming it into flash,i get a different file with the following things... Nios II Introduction Network Settings: IP Address: 192.168.7.44 MAC Address: 00-07-ed-0f-05-49 how to display our contents after programming it into flash.if anybody is expert in nios II IDE and on web server program on nios II,please help me. thnak you manishLink Copied
hi,
my problem is solved and now i can serve any web site using web server. thank you- Mark as New
hi,
ive one more problem,how to display html string on lcd of nios II.- Mark as New
--- Quote Start --- originally posted by manishtirpude@Apr 25 2006, 03:43 AM hi,
ive one more problem,how to display html string on lcd of nios ii.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14645)
--- quote end ---
--- Quote End --- Have you tried fopen,printf to the "/dev/lcd_display" device? There's some sample code, which does this, in the count_binary example. - slacker
I'm trying to modify the contents of the ro_zipfs.zip file and then program the flash. However, when i try to open the webpage i get the error 404 (Can't find the requested file file. Have you programmed the flash filing system into flash?) It seems that when im modifying the file, something wrong is happening and the file is not being downloaded on the flash :S any idea how to perform this correctly? Thank you in advance :)- Mark as New
i tried to run the web server demo but getting error " MicroC/OS-ii component unavailable" , not sure how to solve it?
It's supposed to be part of the Nios EDS. Which version do you have and are you sure it was installed correctly?
i installed version 6 and i tried it on win8 and winXP, but still the problem perisists...... i do think i have installed correctly......
I'm not sure when uC OS was included with the Nios EDS, but you may want to try a more recent version.
