Hello
I have a custom h/w for NiosII development using Cyclone III FPGA. I have 512k x 16 bit cypress SRAM. In SOPC builder I created a custom 16 bit Avalon tristate slave for SRAM interface. For some simple data transfer (in application code) it worked fine. But when I tried to put my program into my SRAM, things went wrong. It shows; Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00412068: verified Initializing CPU cache (if present) OK Downloading 00300000 ( 0%) Downloading 00408020 (91%) Downloaded 4KB in 0.0s Verifying 00300000 ( 0%) Verify failed between address 0x300000 and 0x300D87 Leaving target processor paused Is it possibe to download your code into a 16 bit avalon tristate slave???:eek:Link Copied
There could be a couple of reasons here.
And of course it is possible to mix different bit widths, the avalon switch fabric takes care about it when a master accesses a slave with a different bit width 1. do you get any timing waring during quartus compilation ? 2. have you checked your external signals against over and undershot ? undershots can lead to shifting the signal levels in a way that a component "thinks" it is active. 3. how do you do you timing control, via wait states or did set up the timing for setup access and hold ? 4. is you external memory attached as a memory or a register, i am asking about the alignment.
