About Telnetd
Hello :
I have questions about telnetd on the microtronix's linux distribution on NiosII :
I use busybox as my basic filesystem,and use the Microtronix's pre-built networking apps
like "route" "ping" "ftpd" "telnetd" "boa" ...etc.
and it seems that the pre-built "telnetd" will invoke "login" with a "-t" option
but, the Busybox's "login" doesn't accept a "-t" option.
so when i telnet to the target,then it shows a error message :
illegal option "-t"
how can i solve the problem?
i am thinking in two ways:
1. modify the source code in the $LINUX_NE_ROOT/apps/telnetd ,then rebuilde the appilcation without invoking login with "-t"
=>but i don't know how to do.....
2. use the busybox's networking apps ,
=>how to install them properly?
thanks very much http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
Another alternative is adding the small login (the one not from busybox) to your filesystem. It is a very simple program (the source is only severl lines of C code).
