Altera DE2 & NIOS newbie :(
okie.. im aware the next few lines are gonna be very silly, but i really have no idea how to go about this board Altera DE2 and the NIOS 2. I am to use the board for a real time monitoring application for human motion, this is for my Final Year Project. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
I have already installed all softwares that came along with the box, but i still cant seem to get acess into the programin console, i have already powered up the board and seen fancy light n display flashing, but thats bout all i have managed to come up with so far http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
Any form of help or recommendation pointing me in the right direction would be greatly appreciated http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
You should been provided for tutorials and demonstrations.
That&#39;s a very good starting point to understand the whole thing.
You definetly want to get the DE2_System CD, see http://www.altera.com/education/univ/mater...-de2-board.html (http://www.altera.com/education/univ/materials/boards/unv-de2-board.html
-Pascal
--- Quote Start ---
originally posted by evilynux@Sep 5 2006, 11:33 PM
you should been provided for tutorials and demonstrations.
that&#39;s a very good starting point to understand the whole thing.
you definetly want to get the de2_system cd, see http://www.altera.com/education/univ/mater...-de2-board.html (http://www.altera.com/education/univ/materials/boards/unv-de2-board.html
-pascal
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18080)
--- quote end ---
--- Quote End ---
Thanx a million http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif will look into it
i seem to be having a problem compiling a normal C program i get the following screen:
**** Incremental build of configuration Debug for project hello_world_0 ****
make -s all
"X`which cygpath.exe 2> /dev/null`" was unexpected at this time.
F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:152: `: No such file or directory
F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:152: "F:/Projects/GSE4806/Altera/kits/nios2_60"`: No such file or directory
F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:152: /components/altera_hal/build/gnu_rules.mk: No such file or directory
F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:156: `: No such file or directory
F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:156: "F:/Projects/GSE4806/Altera/kits/nios2_60"`: No such file or directory
F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:156: /components/altera_hal/build/gtf_rules.mk: No such file or directory
make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk&#39;. Stop.
Build completed
are there suppose to be so many errors?? its just a simple hello world program http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
and when i run the Quartus Programmer for the sof file i get the following error
Info: Started Programmer operation at Mon Sep 18 02:13:21 2006
Error: Can&#39;t configure device. Expected JTAG ID code 0x020840DD for device 1, but found JTAG ID code 0x020B40DD.
Error: Operation failed
Info: Ended Programmer operation at Mon Sep 18 02:13:21 2006
the hardware setup is set to the USB port of the blaster, any pointers on how i can over come this?
Hopeful http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
Agape
