Assemble in C
hi
i am i am new to NIOS. I want to insert an asm code in C prog...
In microcontroller prog..... i use# pragma...
this command is not working in NIOS IDE. plz tell me in what way i can insert my
--- Quote Start ---
originally posted by sriram_k@Mar 20 2007, 08:24 AM
hi
i am i am new to nios. i want to insert an asm code in c prog...
in microcontroller prog..... i use# pragma...
this command is not working in nios ide. plz tell me in what way i can insert my
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22362)
--- quote end ---
--- Quote End ---
Have a try on the inline asm, which basically enable users to write assembly instructions directly. For example:
asm ("stw    r0,  16(sp)");
--- Quote Start ---
originally posted by arrive+mar 20 2007, 04:13 pm--><div class='quotetop'>quote (arrive @ mar 20 2007, 04:13 pm)</div>
--- quote start ---
<!--quotebegin-sriram_k@Mar 20 2007, 08:24 AM
hi
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22365)</div>
[/b]
--- Quote End ---
Just a small example:
__asm__ __volatile__("mov r2, %0 \n\t"
"mov r3, %1 \n\t"
"ldw r4, 0(r2) \n\t"
"stw r4, 312(r3) \n\t"
: // No output needed !
:"r"(var_a),"r"(var_b) // Input
:"r2","r3","r4" // used registers
Have a look at http://homepage.fudan.edu.cn/%7eeuler/gcc_asm/inline-1.html (http://homepage.fudan.edu.cn/%7eeuler/gcc_asm/inline-1.html
Christian
TO_BE_DONE
--- Quote Start ---
originally posted by sriram_k+mar 21 2007, 12:13 pm--><div class='quotetop'>quote (sriram_k @ mar 21 2007, 12:13 pm)</div>
--- quote start ---
--- quote start ---
originally posted by christian_80@mar 21 2007, 03:45 am
--- quote start ---
hi
--- quote end ---
--- Quote End ---
[/b]
--- Quote End ---
"mov r3, %1 \n\t"
Christian
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22369)</div>
[/b]
--- Quote End ---
thanks christian...
its working fine.. also i found the link posted in group is very useful.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
till now i was simulating the code in simulator only....
i had DE2 board...
could u plz.. send me any link regarding the syntax in C code for nios processor to handle the I/O ports and all....
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22388)</div>
[/b]
--- Quote End ---
Many information can be found in the Nios2 Software Developer Guide on altera.com
A simple 32bit IO Component can be accessed by:
IORD_32DIRECT(PERIPHERAL_NAME_BASE(defined in the SOPC Builder),OFFSET,VALUE)
IRWR_32DIRECT(PERIPHERAL_NAME_BASE,VALUE)
Christian
