12606 Discussions
Automatically create SREC file after build
I want to automatically create a SREC file from the elf file after the build. I know the command to use is as follows:
nios2-elf-objcopy -O srec MyProg.elf MyProg.srec
The thing that I do not know how to do is get the IDE (NIOS II V1.1.0 Build 137) to automatically do that after each build. Any help would be appreciated.
thanx
See the thread: "touch file (http://www.niosforum.com/forum/index.php?act=st&f=17&t=1425)" for a discussion on how to add additional make targets to the IDE build process.
In your case you will need to use a rule of the form:
MyProg.srec: MyProg.elf
nios2-elf-objcopy -O srec $< $@
Thanx, it gets me closer, but I still have a problem. I have a 3 projects in my Workspace. It gives me an error when I build because one of the projects builds before the the desired elf file is created. Therefore, I get errors in the build. Is there a way to only run my little make file for a particular project?
After a little more investigating, I came across &#39;External Tools Builder&#39; in properties. I tried just writing a simple shell script that does the nios2-elf-objcopy, but I get an error stating that there was an error in the command line. Not much help from that message http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
The IDE seems to be a lot fuzzy about this. It seems simple what I want to do. I just cannot seem to find the needed info....
