12615 Discussions
Boot failures when zImage size goes a little over 3MB?
Has anyone else seen an issue like this?
A zImage that's 3.0MB (4.6MB uncompressed), the kernel boots without fault. The vmlinux image, when stored as a u-boot uImage also boots.
When I try to nios2-download a zImage that's 3.2MB (4.9MB uncompressed), the kernel fails to boot in random ways, depending on the size of the kernel. In one case, it was an assert(mm == &init_mm). Another case, it was infinitely looping in the initramfs decompression code. In other cases, the debugger can't generate a backtrace. The size difference is the difference between turning on/off in-kernel UBI support. The failure also happens when I try to boot the kernel as a u-boot uImage also.
I've tried all of the different compression options for initramfs and uImage, with no change in functionality.
My target system has 16MB of RAM and normally shows plenty of room free:
/> free
MemTotal: 13560 kB
--Steve
Hi Steve,
did you try to increase the parameter 'Link address offset for booting'?
This is from the old NiosWiki:
<div class='codetop'>CODE</div><div class='codemain' style='height:200px;white-space:pre;overflow:auto'>If your kernel image is large, you will need to change this config.
Processor type and features-->(0x00500000) Link address offset for booting.
The zImage load address is ( your sdram base address + link address
offset ). The boot loader will uncompress the code to the beginning of
sdram. If the uncompressed code is bigger than the default 5M, the two
area will overlap and corrupt. The compressed image offset should be
adjusted to a higher value when the kernel image is big, eg, large
files in romfs dir. You can change this value to about 2/3 of the size
of your sdram, eg, 20M out fo 32M. I suggest 2/3 because the gzip
compression ratio is about 1:2. The zImage boot loader does not
relocate/move itself.
</div>
We had to increase it to:
kernel configuration --> Processor type and features ---> (0x01300000) Link address offset for booting
Good luck,
Ricardo.
<div class='quotetop'>QUOTE (jasinski @ Jul 10 2009, 04:42 PM) <{post_snapback}> (index.php?act=findpost&pid=23070)</div>
--- Quote Start ---
Hi Steve,
did you try to increase the parameter &#39;Link address offset for booting&#39;?[/b]
--- Quote End ---
I haven&#39;t tried that yet. Thanks for the info!
Finally, back to this issue...
When I change the link address offset for booting to 0x00800000, zImage still wont load.
Also, the corresponding linux-2.6.x/vmlinux image wont load from gdb/insight nor when wrapped in a uImage for u-boot.
It&#39;s consistently hitting the BUG(mm == &init_mm); line in linux-2.6/kernel/fork.c:__mmdrop.
In this example, it&#39;s the initramfs being bigger that&#39;s preventing bootup (but turning on UBI and other kernel features causes it as well):
Will load:
vmlinux: 26028261
zImage: 3016537
System.map:__initramfs_start: 0x052919b8
System.map:_end: 0x05454575
Wont load:
vmlinux: 26115445
zImage: 3117081
System.map:_end: 0x0546cf75
Any other ideas? For PowerPC, they suggested increasing the initial memory map size. I haven&#39;t figured out the nios2 equivalent yet.
I&#39;m not sure why this fixes the problem, but this does indeed result in a bootable kernel, even when I built a zImage that came out to 4.7MB.
Could someone pass the info on to the nios2-dev list?
--Steve
diff --git a/arch/nios2/kernel/vmlinux.lds.S b/arch/nios2/kernel/vmlinux.lds.S
--- a/arch/nios2/kernel/vmlinux.lds.S
+++ b/arch/nios2/kernel/vmlinux.lds.S
@@ -112,6 +112,7 @@ SECTIONS
__con_initcall_end = .;
SECURITY_INIT
+ . = ALIGN(PAGE_SIZE);
.init.ramfs :
. = ALIGN(4);
@@ -119,6 +120,7 @@ SECTIONS
*(.init.ramfs)
__initramfs_end = .;
__init_end = .;
_end = . ;
Please try this patch instead. And let me know if it fix your problem.
Cheer,
Hippo
diff --git a/arch/nios2/kernel/vmlinux.lds.S b/arch/nios2/kernel/vmlinux.lds.S index a169ed6..13f289a 100644 --- a/arch/nios2/kernel/vmlinux.lds.S +++ b/arch/nios2/kernel/vmlinux.lds.S @@ -117,6 +117,7 @@ SECTIONS         . = ALIGN(4);         __initramfs_start = .;         *(.init.ramfs) +        . = ALIGN(4);         __initramfs_end = .;     }        __init_end = .;
Hi Hippo,
I tried your patch. A 3.0MB and 3.5MB kernel loads, so the patch is good for my purposes.
--Steve
<div class='quotetop'>QUOTE (pandemic @ Aug 8 2009, 01:08 AM) <{post_snapback}> (index.php?act=findpost&pid=23454)</div>
--- Quote Start ---
Hi Hippo,
--Steve[/b]
--- Quote End ---
Thanks,Steve.
I will apply this patch when the sopc server is back on Monday.
- Hippo
