Building Linux application
Not sure if I should have put this under "Software discussion" or not, but here goes:
I'm trying to build a Linux application using Altera's NIOS-II IDE with Microtronix plugin. The program will be run under uCLinux, of course. =]
I have all the source and header files under the project already. Now it's time to build it.
Then I found out I had to create my own makefile. So I did, a simple one. It just goes through all the directories and compile the source code with the right# include directories (for header files, and things like POSIX thread).
However, it didnt work, and I found out from the Microtronix's example Makefile that it looks rather different from a regular makefile. (i.e. it includes things like Rules.mak)
So, I just wanted to at least get the program to compile. So I instead used Altera's project -> managed library project. Then I got it to compiled, because it automatically created the makefile, and all I had to do was supply the right# include directories under the Project options -> Preprocessor stuff.
Umm..as a newbie, I&#39;m not sure about how to go on. I need some sort of guide on how to create the makefile specifically for the Microtronix Linux app. Could anyone shed lights please? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
Hi ShaChris23,
Well ... you&#39;re in luck! The "Nios II Linux Reference Guide" is probably just the
guide you need :-) It is in your altera/kits/nios2/documentation/linux directory.
After reading the section, "Creating a Makefile", you can read through the many
Makefiles in the examples tree -- it&#39;s not very exciting, but you&#39;ll probably find most
of your answers there.
--Scott
I&#39;m trying to do the same, and I read that referene guide, create my makefile, but when I compile I get an error for each source file like the following one:
make: *** No rule to make target `display.c&#39;, needed by `display.o&#39;.
And I do have a rules.mak file !
Can anybody help me with that ?
--- Quote Start ---
originally posted by shachris23@Dec 28 2005, 11:24 PM
umm..as a newbie, i&#39;m not sure about how to go on. i need some sort of guide on how to create the makefile specifically for the microtronix linux app. could anyone shed lights please? http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11831)
--- quote end ---
--- Quote End ---
take a look at that topic "How solve this problem?" from singerpop
Warm Regards
ShaChris23,
You should really work on Linux, a Makefile is not needed to build a simple program.
Even you want a Makefile, you can write it in the way that you are familier.
Check this link,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
