12748 Discussions
Cannot set breakpoint in FLASH
I'm trying to set a breakpoint in FLASH memory. When I do, execution pauses at PC, and the following error appears on the log:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Cannot insert breakpoint 8.
Error accessing memory address 0x1033e4: (undocumented errno -1).[/b]
--- Quote End ---
Are memory writes needed for setting breakpoints? Breakpoints for internal ROM work OK, so it doesn&#39;t make apparent sense.
Looks like I have a workaround - insert a break instruction into the code:
asm ("break");
This also gets around the "set breakpoint at arbitrary address" problem as well http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
The internal ROM isn&#39;t really readonly, so it allows you to set a breakpoint. The best way to do what you want is to turn on the hardware breakpoints. You will get a limited number of hardware breakpoints, but it will allow you to change them without reflashing the code.
