12748 Discussions
Errorwhile building Application Project
While Building Application Project I am using the hello.c file in
/apps/samples/hello folder
Makefile and the hello.c are added in the same project folder after Create Make Targret I am trying to Build Projectit gives error :
make -k all
Makefile:15: ../Rules.mak: No such file or directory
make: *** No rule to make target `../Rules.mak'.
make: Failed to remake makefile `../Rules.mak'.
make: *** No rule to make target `hello.exe', needed by `all'.
make: *** No rule to make target `hello.gdb', needed by `all'.
make: Target `all' not remade because of errors.
Whats the reason?
change in your makefile TOPDIR = .. into TOPDIR = ./
--- Quote Start ---
originally posted by helmchen@Oct 26 2005, 05:42 PM
change in your makefile topdir = .. into topdir = ./
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10588)
--- quote end ---
--- Quote End ---
Thanks it worked
One more help please
How to run this application on the (linux project) .sof downloaded on FPGA.
After doing run it gives Verifying failed
Target processor paused
Thanks and Regards
try to upload the file with ftp for example or add hello.exe to filesystem and upload the filesystem.
But uploading with ftp is the way to do.
--- Quote Start ---
but uploading with ftp is the way to do.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10591)
--- quote end ---
--- Quote End ---
I am completely new to all this can you suggest some doc or give the steps
Thanks and Regards
--- Quote Start ---
--- quote end ---
--- Quote End ---
I&#39;m experiencing a likely error when trying to build my µClinux application (although it build with no error as a C/C++ application)
make: *** No rule to make target `display.c&#39;, needed by `display.o&#39;.
And so for each source file in the project directory.
I&#39;ll be grateful if you can help me with that.
Warm Regards
--- Quote Start ---
--- quote end ---
--- Quote End ---
can we really upload the file to the bin directory? Since the filesystem is read only
Warm Regards
