12612 Discussions
Fixing smsc91c111 to 10Base-T.
I've built a prototype board which includes the Cyclone III + smsc91c111 ethernet chips.
Under Quartus-II version 9.0 + Nios II + muCOS-II + smsc91c111, the auto-negotiation fails during initialization of the driver. Could you tell me how to modify the driver so the chip skips the auto-negotiation, and fixes to 10Base-T (or 100Base-T)?
Hi Mhori,
Search IP device drivers for the file smsc_phy.c.
You'll find the s91_phy_init() function which performs auto negotiation.
With minor changes you can:
- skip auto-negotiation
- ignore negotiation errors
- force the link speed
In the first two cases you must ensure your system can restart auto-negotiation when needed.
Cris
