12619 Discussions
Going from DE2 to DE2-115 Ethernet
So I successfully developed my code on the DE2 board to working, essentially it's a variation on BTXSistemas' DE2_Net to introduce some randomization and other features. However I now need to implement it on the DE2-115 which has a much different Ethernet core. I'm trying to use the Web Server example as a starting point but it's so much higher level than I really need that I'm getting nowhere. Basically what I need is to figure out the equivalent function of
TransmitPacket(TXT,Length)
on the DE2-115. Can anyone help me out here? Thanks in advance and I've included my main code below.
#include "alt_types.h" // alt_u32 # include "altera_avalon_pio_regs.h" //IOWR_ALTERA_AVALON_PIO_DATA # include "sys/alt_irq.h" // interrupt # include <stddef.h> # include "sys/alt_flash.h" # include "sys/alt_flash_types.h" # include "sys/alt_alarm.h" // time tick function (alt_nticks(), alt_ticks_per_second()) # include "sys/alt_timestamp.h" # include "sys/alt_stdio.h" # include <fcntl.h> # include "nios2_ctrl_reg_macros.h" # include <io.h> # include <stdio.h> # include <unistd.h> # include <stdlib.h> # include <string.h> # include "LCD.h" # include "system.h" # include "DM9000A.C" # include "hello_led.h" # include "test.h" unsigned int aaa,rx_len,i,packet_num, times, counter; unsigned char RXT; unsigned char SND; // Payload buffer unsigned int IPsource_1,IPsource_2,IPsource_3,IPsource_4; unsigned int IPdestination_1,IPdestination_2,IPdestination_3,IPdestination_4; unsigned int IPchecksum1,IPchecksum2,IPchecksum3,IPchecksum4,IPchecksum5; unsigned int Mac_source1, Mac_source2, Mac_source3, Mac_source4, Mac_source5, Mac_source6; unsigned int Mac_dest1, Mac_dest2, Mac_dest3, Mac_dest4, Mac_dest5, Mac_dest6; unsigned int times, lenght_h, lenght_l; unsigned int flenght, IPlenght_h, IPlenght_l, data_lenght, IPlenght; unsigned int delay, Mode; int data0, data1, data2, data3, data4, data5, data6, data7; int main(void) { LCD_Test(); IPsource_1 = 0xC0; // Assign ie: 192.168.0.44 IP for the DE2 IPsource_2 = 0xA8; IPsource_3 = 0x00; IPsource_4 = 0x2C; IPdestination_1 = 0x??; // Insert your IP data here IPdestination_2 = 0x??; IPdestination_3 = 0x??; IPdestination_4 = 0x??; Mac_dest1 = 0x00; // Insert your MAC address data here Mac_dest2 = 0x03; Mac_dest3 = 0x25; Mac_dest4 = 0x43; Mac_dest5 = 0x6A; Mac_dest6 = 0x27; Mac_source1 = 0x01; // Assign a MAC address for DE2 Mac_source2 = 0x60; Mac_source3 = 0x6E; Mac_source4 = 0x11; Mac_source5 = 0x02; Mac_source6 = 0x0F; delay = 0; Mode = 0; data_lenght = 1468; // Maximun Data lenght 1468 bytes flenght = data_lenght + 0x2E; //Total packet lenght lenght_h = ((data_lenght+8) & 0xFF00)>>8; // Convert in H byte and L byte lenght_l = ((data_lenght+8) & 0x00FF); IPlenght = data_lenght + 8 + 20; // IP Lenght for IP header IPlenght_h = (IPlenght & 0xFF00)>>8; // Convert in H byte and L byte IPlenght_l = (IPlenght & 0x00FF); // Calculating the IP checksum IPchecksum1 = 0x0000C511 + (IPsource_1<<8)+IPsource_2+(IPsource_3<<8)+IPsource_4+ (IPdestination_1<<8)+IPdestination_2+(IPdestination_3<<8)+(IPdestination_4)+ (IPlenght_h<<8) + IPlenght_l; IPchecksum2 = ((IPchecksum1&0x0000FFFF)+(IPchecksum1>>16)); IPchecksum3 = 0x0000FFFF - IPchecksum2; IPchecksum4 = (IPchecksum3 & 0xFF00)>>8; IPchecksum5 = (IPchecksum3 & 0x00FF); srand ( time(NULL) ); unsigned char TXT = { Mac_dest1,Mac_dest2,Mac_dest3,Mac_dest4,Mac_dest5,Mac_dest6, //Destination MAC Mac_source1,Mac_source2,Mac_source3,Mac_source4,Mac_source5,Mac_source6, //Source MAC 0x08,0x00, //Type 0xFF, // Header Length 0x22, //ECN-CE 0x33,0x44, //total Length 0x55,0x66, //Identification 0x77,0x88, //Fragment Offset 0x99, //Time to Live 0xAA, //Protocol 0x55,0x66, //Checksum IPsource_1,IPsource_2,IPsource_3,IPsource_4, //Source IP //0x77,0x88,0x99,0xAA, //Source IP IPdestination_1,IPdestination_2,IPdestination_3,IPdestination_4, //Destination IP 0x99,0xAA,0x55,0x66,0x77,0x88, //Data 0x55,0x66,0x77,0x88,0x99,0xAA, //Data 0x55,0x66,0x77,0x88,0x99,0xAA, //Data 0x55,0x66,0x77,0x88,0x99,0xAA, //Data 0x00,0x00,0x00,0x20,0x99,0xAA}; //Data unsigned char TXT2 = { Mac_dest1, Mac_dest2, Mac_dest3, Mac_dest4 ,Mac_dest5, Mac_dest6, Mac_source1, Mac_source2, Mac_source3, Mac_source4, Mac_source5, Mac_source6, 0x08, 0x00, 0xFF, 0x22, IPlenght_h, IPlenght_l, 0x55, 0x66, 0x77, 0x88, 0x99, 0xAA, IPchecksum4, IPchecksum5, IPsource_1, IPsource_2, IPsource_3, IPsource_4, IPdestination_1, IPdestination_2, IPdestination_3, IPdestination_4, 0x04, 0x00, 0x04, 0x00, lenght_h, lenght_l, 0x00, 0x00}; for (i = 0; i < 42; i++) // Load the TXT in the SND (ethernet packet). SND = TXT2; for (i = 42; i < flenght-4; i++) // generating the data to send. SND = i-42; SND = 0x35; // This checksum is not correct, but also the net recieve the packets correctly. SND = 0x15; // To do, calculate checksum. SND = 0xF0; SND = 0x13; DM9000_init(); init_button_irq(); LCD_TestSWNR(); //Add ability to change data rates //Modes, send out data at 34 Mbit/s, send data out in bursts, storing in RAM until full //How to get MAC/IP of other INK Board/s and hard code in or software get while (1) { alt_u8 button; button = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE); bool bSpeedDown, bSpeedUp, bMode; if(button & 0x08) bSpeedDown = FALSE; else{ LCD_TestDS(); delay += 100; msleep(1000); } if(button & 0x04) bSpeedUp = FALSE; else{ if(delay != 0){ LCD_TestIS(); delay -= 100; } else LCD_TestMax(); msleep(1000); } if(button & 0x02) bMode = FALSE; else{ Mode++; delay = 0; if(Mode == 0) LCD_TestSWNR(); else if(Mode == 1) LCD_TestSWR(); else if(Mode == 2) LCD_TestHWPR(); else if(Mode == 3) LCD_TestHWFR(); else if(Mode == 4) LCD_TestP(); else{ Mode = 0; LCD_TestSWNR(); } msleep(1000); } if(Mode == 0){ //SW Not Random Data Generation TransmitPacket(SND,flenght); // Send repetitively 1468 bytes of data. times++; } else if(Mode == 1){ //SW Random Data Generation for (i = 42; i < flenght-4; i++) // generating the data to send. SND = rand() % 255; TransmitPacket(SND,flenght); // Send repetitively 1468 bytes of data. times++; } else if(Mode == 2){ //HW Repeating Packet Data unsigned int data = IORD_ALTERA_AVALON_PIO_DATA(EXPANSION_JP1_BASE); data0 = data & 0x1; data1 = data & 0x10; data1 >>= 3; data2 = data & 0x100; data2 >>= 6; data3 = data & 0x2000; data3 >>= 10; //Should be 9 data4 = data & 0x20000; data4 >>= 13; //Should be 12 data5 = data & 0x200000; data5 >>= 16; //Should be 15 data6 = data & 0x1000000; data6 >>= 18; data7 = data & 0x10000000; data7 >>= 21; data = data0 | data1 | data2 | data3 | data4 | data5 | data6 | data7; for (i = 42; i < flenght-4; i++) // generating the data to send. SND = data; TransmitPacket(SND,flenght); // Send repetitively 1468 bytes of data. times++; } else if(Mode == 3){ //HW Completely Random for(i=34; i < 64; i++){ unsigned int data = IORD_ALTERA_AVALON_PIO_DATA(EXPANSION_JP1_BASE); data0 = data & 0x1; data1 = data & 0x10; data1 >>= 3; data2 = data & 0x100; data2 >>= 6; data3 = data & 0x2000; data3 >>= 10; //Should be 9 data4 = data & 0x20000; data4 >>= 13; //Should be 12 data5 = data & 0x200000; data5 >>= 16; //Should be 15 data6 = data & 0x1000000; data6 >>= 18; data7 = data & 0x10000000; data7 >>= 21; data = data0 | data1 | data2 | data3 | data4 | data5 | data6 | data7; TXT = data; } TransmitPacket(TXT,0x40); times++; } else if(Mode == 4){ //Pause msleep(10);} IOWR(SEG7_DISPLAY_BASE, 0, times); // Show in hex digits the# of packets sent usleep(delay); } return 0; }
Hi driscoll42,
did you get any result from this project. could you please tell us the out come if there is any.
No, sorry. I never got it working properly.
