12620 Discussions
Help! GCC compiling error:arm-linux-gnueabihf-gcc:not found
I'm doing gcc compiling on ubuntu according to the tutorial:my_first_hps.
jungu@ubuntu:~/altera/14.0/embedded/my_first_hps$ arm-linux-gnueabihf-gcc /home/jungu/altera/14.0/embedded/ds-5/bin/arm-linux-gnueabihf-gcc: 18: exec: /home/jungu/altera/14.0/embedded/ds-5/sw/gcc/bin/arm-linux-gnueabihf-gcc: not found
BUT it is there!!!!
jungu@ubuntu:~/altera/14.0/embedded$ cd ds-5/sw/gcc/bin jungu@ubuntu:~/altera/14.0/embedded/ds-5/sw/gcc/bin$ ls arm-linux-gnueabihf-addr2line arm-linux-gnueabihf-gprof arm-linux-gnueabihf-ar arm-linux-gnueabihf-ld arm-linux-gnueabihf-as arm-linux-gnueabihf-ld.bfd arm-linux-gnueabihf-c++ arm-linux-gnueabihf-ldd arm-linux-gnueabihf-c++filt arm-linux-gnueabihf-ld.gold arm-linux-gnueabihf-cpp arm-linux-gnueabihf-nm arm-linux-gnueabihf-ct-ng.config arm-linux-gnueabihf-objcopy arm-linux-gnueabihf-elfedit arm-linux-gnueabihf-objdump arm-linux-gnueabihf-g++ arm-linux-gnueabihf-pkg-config arm-linux-gnueabihf-gcc arm-linux-gnueabihf-pkg-config-real arm-linux-gnueabihf-gcc-4.7.3 arm-linux-gnueabihf-ranlib arm-linux-gnueabihf-gcc-ar arm-linux-gnueabihf-readelf arm-linux-gnueabihf-gcc-nm arm-linux-gnueabihf-size arm-linux-gnueabihf-gcc-ranlib arm-linux-gnueabihf-strings arm-linux-gnueabihf-gcov arm-linux-gnueabihf-strip arm-linux-gnueabihf-gfortran
I've been struggling for days, I'm new to linux OS. Is there anyone can help me? thanks
You just download it but haven't installed it. You can turn to this page to learn how to build a corss compliation environment :http://www.rocketboards.org/foswiki/documentation/gsrd131gittrees#build_toolchain
I think Jungu uses the arm compiler that comes with SoCEDS package. I'm on Ubuntu, and I'm getting the same issue when I try to compile the hello_world example,
Did you solved this issue? If so, tell me, please, how you fixed it!
actually I forgot how I fixed this problem. I tried windows OS later. I found there is a mistake in the makefile. I don't whether it can work in ubuntu. You can try this. Here is the makefile code:
TARGET = my_first_hps
CROSS_COMPILE = arm-linux-gnueabihf-
CFLAGS = -g -Wall -I
${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib/include
LDFLAGS = -g -Wall
CC = $(CROSS_COMPILE)gcc
ARCH= arm
build: $(TARGET)
$(TARGET): main.o
$(CC) $(LDFLAGS) $^ -o $@
%.o : %.c
$(CC) $(CFLAGS) -c $< -o $@
.PHONY: clean
clean:
rm -f $(TARGET) *.a *.o *~
Hope you can fix it.
Thank you Jungu for the reply,
I had fixed the issue by reinstalling SOC EDS.
Everything is fine now!.
