Hi!
I've made a board with cpld and flash as in Cyclone Development Kit, but different is cpld EPM3128A only. I ran it on Quartus 4.0 (SP1) and NIOS 1.0 (SP1) and it is configuring and working OK. I try to configure it in new version of Quartus 4.2 with SP1 single and NIOS 2 1.1, but when I was programming it by Flash Programmer appear errors. I've changed a JTAG_UART in custom board design and added a reset_delay block but error is the same. Maybe someone had this problem before? Thanks. Error: # ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd C:/altera/qdesigns42/CamelotProject1/software/CamelotProject1/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --flash=U5 --offset=0x00700000 --input=C:/altera/q designs42/CamelotProject1/CamelotProject1.sof --output=CamelotProject1.flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert C:/altera/qdesigns42/CamelotPro ject1/CamelotProject1.sof CamelotProject1.rbf Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Thu Mar 24 13:18:37 2005 Info: Elapsed time: 00:00:00 # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=CamelotProject1.flash --sof=$ SOPC_KIT_NIOS2/components/Camelot_Custom_Board/system/Camelot_Custom_Board.sof - -cable='USB-Blaster [USB-0]' --base=0x00800000 24.03.2005 13:18:39 - (INFO) nios2-flash-programmer: Launching Quartus Programme r to download: C:/altera/kits/nios2/components/Camelot_Custom_Board/system/Camelot_Custom_ Board.sof Send (64) failed. Unable to synchronize with target. 24.03.2005 13:19:19 - (SEVERE) nios2-flash-programmer: Error opening target hard ware 24.03.2005 13:19:19 - (SEVERE) nios2-flash-programmer: In order to program flash, you must first create a purpose-built flash-programming design (i.e. FPGA configuration) and associate it with your particular board. The Nios development kit is delivered with purpose-bui lt flash-programming designs pre-built for several development boards. If you wi sh to program flash on your own board, you must first create a flash-programming design. The process of creating a flash-programming design for your board is mostly automated. From a bash-shell, execute this script: mk_target_board --help The help-message includes references to other documentation on programming flash and targeting Nios systems to custom board designs. - exiting. # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --flash=U5 --base=0x00000000 --end=0x800000 --rese t=0x0 --input=CamelotProject1.elf --output=cfi_flash_0.flash --boot=$SOPC_KIT_NI OS2/components/altera_nios2/boot_loader_cfi.srec # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=cfi_flash_0.flash --sof=__NO_ SOF_PLEASE__ --cable='USB-Blaster [USB-0]' --base=0x00800000 24.03.2005 13:19:20 - (INFO) nios2-flash-programmer: SOF-download skipped. Send (8) failed. Unable to synchronize with target. 24.03.2005 13:19:51 - (SEVERE) nios2-flash-programmer: Error opening target hard ware 24.03.2005 13:19:51 - (SEVERE) nios2-flash-programmer: In order to program flash, you must first create a purpose-built flash-programming design (i.e. FPGA configuration) and associate it with your particular board. The Nios development kit is delivered with purpose-bui lt flash-programming designs pre-built for several development boards. If you wi sh to program flash on your own board, you must first create a flash-programming design. The process of creating a flash-programming design for your board is mostly automated. From a bash-shell, execute this script: mk_target_board --help The help-message includes references to other documentation on programming flash and targeting Nios systems to custom board designs. - exiting.Link Copied
--- Quote Start --- originally posted by camelot@Mar 24 2005, 01:31 PM hi!
i've made a board with cpld and flash as in cyclone development kit, but different is
cpld epm3128a only. i ran it on quartus 4.0 (sp1) and nios 1.0 (sp1) and
it is configuring and working ok. i try to configure it in new version of quartus 4.2 with sp1 single
and nios 2 1.1, but when i was programming it by flash programmer appear errors.
i've changed a jtag_uart in custom board design and added a reset_delay block but
error is the same.
maybe someone had this problem before?
thanks.
error:
# ! /bin/sh# # this file was automatically generated by the nios ii ide flash programmer.# # it will be overwritten when the flash programmer options change.#
cd c:/altera/qdesigns42/camelotproject1/software/camelotproject1/debug
# creating .flash file for the fpga configuration
$sopc_kit_nios2/bin/sof2flash --flash=u5 --offset=0x00700000 --input=c:/altera/q
designs42/camelotproject1/camelotproject1.sof --output=camelotproject1.flash
info: *******************************************************************
info: running quartus ii convert_programming_file
info: command: quartus_cpf --no_banner --convert c:/altera/qdesigns42/camelotpro
ject1/camelotproject1.sof camelotproject1.rbf
info: quartus ii convert_programming_file was successful. 0 errors, 0 warnings
info: processing ended: thu mar 24 13:18:37 2005
info: elapsed time: 00:00:00
# programming flash with the fpga configuration
$sopc_kit_nios2/bin/nios2-flash-programmer --input=camelotproject1.flash --sof=$
sopc_kit_nios2/components/camelot_custom_board/system/camelot_custom_board.sof -
-cable='usb-blaster [usb-0]' --base=0x00800000
24.03.2005 13:18:39 - (info) nios2-flash-programmer: launching quartus programme
r to download:
c:/altera/kits/nios2/components/camelot_custom_board/system/camelot_custom_
board.sof
send (64) failed.
unable to synchronize with target.
24.03.2005 13:19:19 - (severe) nios2-flash-programmer: error opening target hard
ware
in order to program flash, you must first create a purpose-built
flash-programming design (i.e. fpga configuration) and associate it with
your particular board. the nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. if you wi
sh
design.
the process of creating a flash-programming design for your board is mostly
automated. from a bash-shell, execute this script:
the help-message includes references to other documentation on programming
flash and targeting nios systems to custom board designs.
- exiting.
# creating .flash file for the project
$sopc_kit_nios2/bin/elf2flash --flash=u5 --base=0x00000000 --end=0x800000 --rese
t=0x0 --input=camelotproject1.elf --output=cfi_flash_0.flash --boot=$sopc_kit_ni
os2/components/altera_nios2/boot_loader_cfi.srec
# programming flash with the project
$sopc_kit_nios2/bin/nios2-flash-programmer --input=cfi_flash_0.flash --sof=__no_
sof_please__ --cable='usb-blaster [usb-0]' --base=0x00800000
24.03.2005 13:19:20 - (info) nios2-flash-programmer: sof-download skipped.
send (8) failed.
24.03.2005 13:19:51 - (severe) nios2-flash-programmer: error opening target hard
ware
lt
sh
design.
- exiting. --- Quote End --- NIOS 1.1 bug?
I have also problems with the ide flash programmer and i decided to use
the NIOS SDK SHELL and shell scripts for programming. in your example, perhaps there is missing the --devive=<device number> part in the call to nios2-flash-programmer try to write your own script to program the flash, e.g edit # ################################################################################ script to flash a file # FILE TO FLASH FLASH_FILE=$1 # PATH TO FLASH PROGRAMMER BOARD FILE BOARD_CONF_FILE=BOARD_1DVI02_EP1C6.sof # CABLE CABLE="USB-Blaster [USB-0]"# NO OF DEVICE in JTAG_CHAIN JTAG_DEVICE=2# BASEADDRESS OF FLASH IN FLASHPROGRAMMERDESIGN (!!! not in APPLICATIONDESIGN) FP_BASEFLASH=0x00800000 # #################### echo ---------------------------------------------------------------------------- echo "PROGRAM FILE : "$FLASH_FILE echo "BOARD FILE : "$BOARD_CONF_FILE echo "CABLE : "$CABLE echo "JTAG-DEVICE : "$JTAG_DEVICE echo "FLASHPRG BASE ADD : "$FP_BASEFLASH echo ---------------------------------------------------------------------------- nios2-flash-programmer --input=$FLASH_FILE --sof=$BOARD_CONF_FILE --device=$JTAG_DEVICE --cable=$CABLE --base=$FP_BASEFLASH if [ $? != 0 ] then echo "--- !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! ---" exit 1 fi echo "### SUCCESS# ## SUCCESS# ## SUCCESS# ## SUCCESS# ## SUCCESS # ##" exit 0- Mark as New
<div class='quotetop'>QUOTE </div>
--- Quote Start --- # script to flash a file[/b] --- Quote End --- Where is the file? And the error says <div class='quotetop'>QUOTE </div> --- Quote Start --- Unable to synchronize with target.[/b] --- Quote End --- Maybe It is the problem that set the inapposite parameters of the common flash interface. Altera says nothing about how to set the parameters. I read the flash datasheet, want to find something about setup/hold/wait time with the Avalon interface, but get nothing. Can anybody give some index?- Mark as New
Hi LiangYi,
the file is given by the command line to the script (Command line parameter $1), you have to call this script in the bash shell (NiosII SDK Shell) )with e.g. "sh flash CamelotProject1.flash"- Mark as New
I added a device number and cable in .sh file, but error the same.
Maybe someone from NIOS developers knows what I should do in this situation. Thx.- Mark as New
To Camelot,
First, have you tested your memory with memtest project? If tested successfully, I think it is the problem of your Flash Programming Design. You should deal with the clk and reset_n pins(in your Flash Programming Design) the same to your real design. I do this and success.- Mark as New
In NIOS 2 1.0 my board works, programmes and configures correctly, from this I think it is bug in new
release of NIOS 2. My question is what I can do to remove this bug?- Mark as New
But I use the latest version, it success.
My SW is Nios II 1.1 Eval + Quartus II 4.2 SP1. HW is Microtronix Cyclone Dev Board. I mean that if Clk Pin in your Flash Programming Design is assigned to the right Pin in your real design and use the same Pll or reset delay circuit.- Mark as New
On my 1C20 Development kit it works too. But not in my board.
