How solve this problem?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
make -k all
make: *** No rule to make target `all&#39;.
When i follow the guide create an application, but makefile always failed as above.
I&#39;m a linux newer.
Can anyone help me?
Thank you.
Those makefiles aren&#39;t a speciality of linux. they are very common (BCB, VC++,GCC)
How does your makefile look ? Maybe take a look at the makefile of the hello program example and try to build it (look a bit closer in the guide):
# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 1
PROJ_NAME = hello
INSTALL_DIR =
PROGS := $(PROJ_NAME).exe
CFLAGS +=
# # You should not need to modify anything beyond this point#
TOPDIR = ..
include $(TOPDIR)/Rules.mak
ifeq &#39;$(DEBUG)&#39; &#39;1&#39;
PROGS += $(PROGS:.exe=.gdb)
endif
all: $(PROGS)
.PHONY: clean
clean:
-rm -f *.[oad] *.elf *.gdb *.bin *.exe
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
I&#39;m sorry to say that it fails again.
This is my makefile.
DEBUG = 1
PROJ_NAME = debug
INSTALL_DIR =
CFLAGS +=
TOPDIR = ..
endif
all: $(PROGS)
.PHONY: clean
clean:
.PHONY: install
install: all
endif
http://
--- Quote Start ---
originally posted by singerpop@Oct 15 2005, 08:31 AM
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
i&#39;m sorry to say that it fails again.
this is my makefile.
# # configurable options#   - set debug = 1 to turn on debugging support#
debug = 1
proj_name = debug
install_dir =
progs := $(proj_name).exe
cflags +=
# # you should not need to modify anything beyond this point#
topdir = ..
include $(topdir)/rules.mak
ifeq &#39;$(debug)&#39; &#39;1&#39;
progs += $(progs:.exe=.gdb)
endif
all: $(progs)
.phony: clean
clean:
.phony: install
install: all
ifeq "$(install_dir)" ""
$(error no installation directory specified)
endif
mkdir -p $(install_dir)/bin
install -v $(filter %.exe, $(progs)) $(install_dir)/bin
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10382)
--- quote end ---
--- Quote End ---
additional,the outline of niosii ide shows that
"mkdir -p $(install_dir)/bin" and
"install -v $(filter %.exe, $(progs)) $(install_dir)/bin" are wrong.
well, I&#39;m in the same trouble, so if you&#39;ve already solved that please let me know how.
thnx
--- Quote Start ---
originally posted by singerpop@Oct 14 2005, 03:51 PM
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
make -k all
make: *** no rule to make target `all&#39;.
when i follow the guide create an application, but makefile always failed as above.
i&#39;m a linux newer.
can anyone help me?
thank you.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10372)
--- quote end ---
--- Quote End ---
you can try this makefile with the standard generated rules.mak
include Settings.mak
include Rules.mak
# put here all the obj files:
OBJS = myfile.o myfile2.o myfile3.o
# specify here your target:
all: myprog.exe
myprog.bin: $(OBJS)
It works for me and normally for you too.
Warm Regards
