How to implement Xvfb?
I would like to know if i can implemente the xvfb in uClinux in and nios plataform.
I've tried to uncompress just like the install said, but the NiosII DSK shell send
me a message like this:
Program too big to fit in memory
I'd apreciate anyone could help...
Einar Gonzalez
Hi... I don't know what xvfb is, but if it's a user application, then it might help to turn on "Large block allocation" within the kernel.
The option is located at:
Processor type and features
--> Allow allocating large blocks (> 1MB) of memory
re-build, upload, an try your app again... (if it&#39;s an app) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
XVFB provides a virtual Xserver that runs without a head or graphics card, so that it is not necessary to have to run a real Xserver.
I&#39;m triying to implemente it to test...but i&#39;m doing it not in the the target, but in the SDK [SOPC Builder]$
Einar
I&#39;m not sure I understand... it sounds like you&#39;re trying to get it running under Cygwin?
I&#39;m trying to uncompress the Xvfb.tgz, bucause i cant do it when i&#39;m running on the target....
Einar
There are plenty of sites out there that provide information about uncompressing .tgz files...
for starters, try: tar -zxf xvfb.tgz
The
-z means that the archive is compressed
-x means extract the files from the archive
-f means that the next argument is the filename to work with
Good luck!
