Hello !
I have a custom NIOS II system with STRATIX II and SSRAM. I am doing this steps for load and start my system: ( All program sections placed in SSRAM) 1. Nios2 compilator create *.elf 2. I convert *.elf to *.bin with "nios2-elf-objcopy.exe 1.elf -O binary --set-start 0 1.bin" 3. I init SSRAM with my *.bin 4. I reset NIOS. In this case working only simple program ( printing constant string to LCD for example). System crash when i writing C-code with variables. How must I load *.elf to SSRAM correctly? Thanks. Sorry for my EnglishLink Copied
I'd start by trying out the Nios II IDE. Here's a document about how to use it (download/debug your code using it)
http://www.altera.com/literature/hb/nios2/n2sw_nii52002.pdf (http://www.altera.com/literature/hb/nios2/n2sw_nii52002.pdf)- Mark as New
Hi Jools,
<div class='quotetop'>QUOTE </div> --- Quote Start --- 3. I init SSRAM with my *.bin[/b] --- Quote End --- How do you init SSRAM with *.bin? I mean from which address. And after initing SSRAM, how do you set your PC register? In my system, my SDRAM_BASED = 0x1000000 Also,all my sectors exist in SDRAM And I copy *.bin to SDRAM from address 0x1000020. After booting, I set PC = 0x10001C8 Then everything work correctly. Note: exception sector occupied the following address: 0x1000020 -- 0x10001C7 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif FYI. David
