12606 Discussions
How to read from a onchip memory
Hello i want to read data from some adress at the onchip memory, i can do it with IORD and IOWR using altera HAL functions. However those functions are not available for me inside the linux
You won't be able to access memory directly from userspace in linux. You'll probably have to write a kernel driver or module. On the other hand, You can access heap memory if it is set in BSP config by using malloc().
hello ...
if you using uClinux no-mmu you can acess the memory using IORD and IOWR
make a c program and cross compile for your design
at uClinux no-mmu you can acess peripherials direct....
cheers
Franz Wagner
if you use uClinux no-mmu .......
use a program like that to test you acess.....
#include <stdio.h> # define BUFFER_MEMORY 0x10000000# define IORD(address, offset) (*(volatile unsigned *)(((address)| 0x80000000)+4*(offset))) # define IOWR(address, offset, value) (*(volatile unsigned *)(((address)|0x80000000)+4*(offset)))=(value) int main() { int op; int valor; int temp; while (1) { printf("\n\n\nDIGITE A OPCAO\n"); printf("1 - ESCREVER\n"); printf("2 - LER\n"); scanf("%d",&op); if (op == 1) { printf("DIGITE O VALOR\n"); scanf("%x", &valor); printf("ESCREVENDO %x\n", valor); IOWR(BUFFER_MEMORY, 2, valor); //IOWR(0x00041040, 0, valor); } else if (op == 2) { printf("LENDO\n"); temp=IORD(BUFFER_MEMORY, 0X2); printf("temp = %x\n", temp); } else { printf("OPCAO INVALIDA\n\n"); } } return 0; }
good luck
Franz Wagner
Thanks Franz, this works with NOMMU but i am using a MMU linux do you have any ideas on how to do it?
hi man
.... i trying use uclinux mmu now.........but i dont know how did that at mmu.........
malloc() calloc() can help i guess........
i will try do .....
cheers....
Franz Wagner
Device driver to acess on chip memory as a char device (must be made inside linux2.6/arch/nios2/driver)
# include <linux/fs.h># include <linux/sched.h># include <linux/errno.h># include <linux/types.h># include <linux/cdev.h># include <linux/kernel.h># include <linux/module.h># include <asm/current.h># include <asm/segment.h># include <asm/uaccess.h># include <asm/io.h> # define DRIVER_NAME "shmem" # define SHARED_MEM_BASE 0x800# define SHARED_MEM_SPAN 2048 typedef struct { int32_t mutex; int32_t reset; } mutex_t; typedef struct { mutex_t *mutex; unsigned char *buffer; } shmem_t; static shmem_t shmem; int shmem_open(struct inode *inode,struct file *filep) { return 0; } int shmem_release(struct inode *inode, struct file *filep) { return 0; } ssize_t shmem_read(struct file *filep ,char *buff, size_t count, loff_t *offp) { int retval; printk(KERN_INFO "read, count %i, off %i\n", count, *offp); if (*offp >= SHARED_MEM_SPAN) { return 0; } if (count > (SHARED_MEM_SPAN - *offp)) { count = (SHARED_MEM_SPAN - *offp); } retval = copy_to_user(buff, (shmem.buffer+*offp), count); if (retval != 0) { printk(KERN_ERR "Kernel to userspace copy failed!\n" ); return retval; } *offp += count; return count; } ssize_t shmem_write(struct file *filep,const char *buff,size_t count,loff_t *offp ) { int retval; if (*offp >= SHARED_MEM_SPAN) { return -ENOSPC; } if (count > (SHARED_MEM_SPAN - *offp)) { count = (SHARED_MEM_SPAN - *offp); } retval = copy_from_user((shmem.buffer+*offp), buff, count); if (retval != 0) { printk(KERN_ERR "Kernel to userspace copy failed!\n" ); return retval; } *offp += count; return count; } struct file_operations shmem_fops={ open: shmem_open, read: shmem_read, write: shmem_write, release:shmem_release, }; static int shmem_init(void) { printk(KERN_INFO "shmem device driver init\n"); if(register_chrdev(222,DRIVER_NAME, &shmem_fops)){ printk(KERN_ERR "failed to register\n"); goto chrdev_error; } shmem.mutex = (mutex_t *)ioremap(MUTEX_BASE, MUTEX_SPAN); if (shmem.mutex == NULL) { printk(KERN_ERR "failed to map mutex\n"); goto mutex_error; } printk(KERN_INFO "mutex %p\n", shmem.mutex); shmem.buffer = (unsigned char *)ioremap(SHARED_MEM_BASE, SHARED_MEM_SPAN); if (shmem.buffer == NULL) { printk(KERN_ERR "failed to map shared memory\n"); goto buffer_error; } printk(KERN_INFO "shmem %p\n", shmem.buffer); printk(KERN_INFO "shmem: mutex.reset %02x\n", shmem.mutex->reset); return 0; buffer_error: iounmap(shmem.mutex); mutex_error: unregister_chrdev(222, DRIVER_NAME); chrdev_error: return -ENODEV; } static void shmem_cleanup(void) { printk(KERN_INFO "shmem device driver unregister.\n"); iounmap(shmem.buffer); iounmap(shmem.mutex); unregister_chrdev(222, DRIVER_NAME); return; } module_init(shmem_init); module_exit(shmem_cleanup);
A program in user land (uclinuxdist/user/program) to read 32 bits per read
# include <unistd.h># include <fcntl.h># include <sys/mman.h> int main() { int fd = 0; int value = 0; int bytes = 0; fd = open("/dev/mutex", O_RDWR); if (fd == NULL) { printf("Erro abrindo mutex\n"); return 1; } bytes = read(fd, &value, sizeof(value)); if (bytes < 0) { printf("Error lendo\n"); return 1; } printf("Valor lido: %x\n", value); bytes = read(fd, &value, sizeof(value)); if (bytes < 0) { printf("Error lendo\n"); return 1; } printf("Valor lido: %x\n", value); lseek(fd, 0, SEEK_SET); bytes = read(fd, &value, sizeof(value)); if (bytes < 0) { printf("Error lendo\n"); return 1; } printf("Valor lido: %x\n", value); close(fd); return 0; }
you are a jedi man..........
I will try this too
