12747 Discussions
How to reduce code footprint for lwIP
I download standalone lwIP realization from here. I use "standart" NiosII reference design. After building lwip_web_server example project I found that code footprint is near 250 Kbytes.
In README file located at : project_directory/lwip-0.7.1/readme I found next text:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
The focus of the lwIP TCP/IP implementation is to reduce the RAM usage
while still having a full scale TCP. This making lwIP suitable for use
in embedded systems with tenths of kilobytes of free RAM and room for
around 40 kilobytes of code ROM.[/b]
--- Quote End ---
So my question: what I have to modifie in project to reduce memory requirements?
How to fit code footprint to <div class='quotetop'>QUOTE </div>
--- Quote Start ---
--- Quote End ---
If 40 Kb is too small than around 100Kb also will be OK.
I&#39;m in a hurry or else I&#39;d be more help.
In the software design doc up on the altera site under NIOS II, it talks about settings to reduce your foot print size. Some ideas are Small C library, no clean exit, etc....
Good-luck
