12612 Discussions
I encounter a sopcbuilder problem
while using new component wizard:
Error: command "quartus_map --generate_hdl_interface=D:/altera/quartus60/work/NL6448BC20_controller_prototype/ce_temp_directory/read1_master.v ce_temp_directory/ce_temp_quartus_project" returned 3
Error (10670): Verilog HDL or VHDL error: cannot create XML design interface for design file D:/altera/quartus60/work/NL6448BC20_controller_prototype/ce_temp_directory/read1_master.v. File: D:/altera/quartus60/work/NL6448BC20_controller_prototype/ce_temp_directory/read1_master.v Line: 1
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error: Processing ended: Wed Mar 14 10:54:26 2007
Error: Elapsed time: 00:00:01
Error: D:/altera/quartus60/work/NL6448BC20_controller_prototype/ce_temp_directory/read1_master.v.xml does not exist
I do not know why.
--- Quote Start ---
error: command "quartus_map --generate_hdl_interface=d:/altera/quartus60/work/nl6448bc20_controller_prototype/ce_temp_directory/read1_master.v ce_temp_directory/ce_temp_quartus_project" returned 3
error (10670): verilog hdl or vhdl error: cannot create xml design interface for design file d:/altera/quartus60/work/nl6448bc20_controller_prototype/ce_temp_directory/read1_master.v. file: d:/altera/quartus60/work/nl6448bc20_controller_prototype/ce_temp_directory/read1_master.v line: 1
error: quartus ii analysis & synthesis was unsuccessful. 1 error, 0 warnings
    error: processing ended: wed mar 14 10:54:26 2007
    error: elapsed time: 00:00:01
error: d:/altera/quartus60/work/nl6448bc20_controller_prototype/ce_temp_directory/read1_master.v.xml does not exist
i do not know why.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22266)
--- quote end ---
--- Quote End ---
Do you use parameters in your HDL by any chance? If so can you copy and paste them into this post. I&#39;ve seen this message before when you have a parameter based on another parameter.
Make sure all your parameters have default values.
Avishay
The problem with parameters inside your verilog source during sopc component generation is not new (but mostly fixed)
if you add a source.v as a hdl file inside the sopc component editor then in priviously versions you couldn&#39;t have a struct like
mymodule ( .... );
parameter EnableLCD = 1;
quartus itself can deal with such parameters, but during sopc component editor this was not possible. i had to remove such parameters, do the sopc job and then re-add the parameter.
Quartus 6.1 and Quartus 7.0 can handle such parameters.
