ISR stack
Hi all,
what stack does ucosii use when entering an ISR?the interrupted task stack or the system stack?
tnx
If you define an exception stack, then it should be the target stack.
If no, it should be system stack...
Thanks for your reply David_Cai,
but now I have this problem: in the system library page, if I include ucosii I can't set the option "use a separate exception stack".Is it normal and why?
tnx in advance
bye
I think it's normal.
Maybe it will lower system complexity.
