I want to access (read/write) dual port ram in my sopc system. How could I do that in my Nios II program? Thanks, CarideeLink Copied
You can use either the IORD/IOWR macros, or directly use C pointers. In the latter case, you must go through the alt_remap_uncached() function to define your pointer, to be sure you bypass the data cache.
Hi Daixiwen,
Thanks alot for your reply. I'd appreciate your help again if you could give me sample of C code using both MACRO and pointer methods to say for example write data to dual port ram address through Nios II cpu. Thanks in advance. Regards, Caridee (http://www.alteraforum.com/forum/member.php?u=4443)- Mark as New
Through the IOWR macro:
IOWR(YOUR_DPRAM_BASE,reg,value)
Where reg is the 32-bit register number (reg = 0 will write at YOUR_DPRAM_BASE, reg = 1 will write at YOUR_DPRAM_BASE+4, etc...) and value is the 32-bit value to write. Using pointers: int *myPointer = (int*)alt_remap_uncached(YOUR_DPRAM_BASE,YOUR_DPRAM_SPAN);
myPointer = value1;
myPointer = value2;
etc...
Hi Daixiwen,
Thanks for the codes... i will try it out... by the way, i am a abit new in using macro. can u pls explain to me why reg = 0 and reg = 1 are differ from 4 bytes? Thanks again, Caridee- Mark as New
The IORD/WR macros read and write 32-bit registers directly. That's why when you increase the register number by one, the macro will access the next 32 bits, i.e. the next 4 bytes.
I am using the On-chip memory (RAM or RAM) in my design. This memory component is described briefly here (http://www.altera.com/literature/hb/qts/qts_qii54006.pdf) (Page 9-6), but I was wondering if there is a more detailed document? I could not find any.
this (http://www.altera.com/literature/hb/nios2/n2cpu_nii5v3_02.pdf)document describes a FIFO memory core, but that's not the one I am using.- Mark as New
I don't think there is any other document about the on-chip RAM.
Hello Daixiwen,
Thank you so much for your explanation. Caridee
