12612 Discussions
Is flash absolutely necessarily?
I'm now using the Microtronx nios2linux-1.4 to run linux on NIOS.
When i build the project, it says that it needs a flash to upload the kernel to, but we don't have a flash in our board, the result is that i cann't go on with it.
Is flash absolutely necessarily?If not, what should i do?
I'm a newer in nios,can anybody give me advice?Thanks in advance!
--- Quote Start ---
originally posted by bogwind@Sep 10 2006, 08:55 AM
i'm now using the microtronx nios2linux-1.4 to run linux on nios.
when i build the project, it says that it needs a flash to upload the kernel to, but we don't have a flash in our board, the result is that i cann't go on with it.
is flash absolutely necessarily?if not, what should i do?
i'm a newer in nios,can anybody give me advice?thanks in advance!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18189)
--- quote end ---
--- Quote End ---
you can download you system in your sdram indirectly.Then run it in sdram.
--- Quote Start ---
originally posted by smalllight+sep 11 2006, 12:27 am--><div class='quotetop'>quote (smalllight @ sep 11 2006, 12:27 am)</div>
--- quote start ---
<!--quotebegin-bogwind@Sep 10 2006, 08:55 AM
i&#39;m now using the microtronx nios2linux-1.4 to run linux on nios.
when i build the project, it says that it needs a flash to upload the kernel to, but we don&#39;t have a flash in our board, the result is that i cann&#39;t go on with it.
i&#39;m a newer in nios,can anybody give me advice?thanks in advance!
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18205)</div>
[/b]
--- Quote End ---
Thank u for your reply!
When i build the project, it says that it needs a flash to upload the kernel to, if there isn&#39;t any flash, the NIOS II IDE wann&#39;t let you go on.
So could you please tell me how could i download the system to sdram indirectily in detail?
So if the IDE wants it, why don&#39;t you offere one?
Even it is not on your board, you can try to add one. Or just edit your PTF-File.
you can use the command " nios2tdownload.exe -g vmlinux",the vmlinux can upload to sdram with jtag.then the linux will run in sdram, you can use command "nios2terminal" to login to your linux system
--- Quote Start ---
--- quote end ---
--- Quote End ---
The flash is needed for the root file system with romfs, if you use the Microtronix&#39;s kit.
You must find other root file system, since you don&#39;t have flash.
You may follow the nios wiki to use initramfs for root fs. It might save a lot of troubles.
