Hi all,
I am trying to use OPTREX LCD module on uclinux ( stratix II board ). I´m using J15 connector to avoid conficts with compact flash card. I have my own display driver designed using altera PIO component. My display driver runs without problems on a NIOS II project. When I put my application on uclinux the kernel reboot. Thanks for any suggestions.Link Copied
I'm sorry, but that's not enough information for me to help... what do you mean when you say you put your application on uClinux?
Hello Ken,
First I created a new 11 bit PIO and write a simple C program to run on NIOS II. The project has 2 files named lcd_16207.h and lcd_16207.c and I can control the LCD using this option. Then I created a new linux application project and put lcd_16207.* files into the new project. When I run the application the kernel reboot when acessing IO from LCD.- Mark as New
I'm guessing that the application compiled properly and that you got it into the filesystem on the Nios II alright. How are you doing your read and writes to the PIO in your Nios II Linux application?
Hello Ken,
I´m using IORD and IOWR macros IOWR(PIO_LCD_0_BASE,0,0); IORD(PIO_LCD_0_BASE,0); The problem was solved : I put the code on lcd_16207.c file into main file application (lcd.c) and now the LCD is OK. Problably Eclipse is causing the problem. Thanks for help- Mark as New
Which file do you include to using IOWR/IORD?
So , in my view, you builde a application software instead of "linux drivers" , isn't it ?- Mark as New
The include files are: nios2_system.h io.h system.h lcd_16207.h The software is an application. I dont know how to make a "linux driver"- Mark as New
Hi!
Is a special driver always necessary to use a LCD, a LED or other devices under Linux? Bye, Lothar.- Mark as New
--- Quote Start --- originally posted by mtuxpe@Aug 26 2005, 03:18 PM hi,
the include files are:
nios2_system.h
io.h
system.h
lcd_16207.h
the software is an application.
i dont know how to make a "linux driver"
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=9310)
--- quote end ---
--- Quote End --- mtuxpe, Can you show me how i can write an application to use the 16207 ? my nios2_system.h doesn't have entries on 16207 ? What do i need to do ? Some help would be good. thanks
dear mtuxpe
could you post the LCD driver code ?thanks- Mark as New
show you code,Maybe someone can help you
Topic Options
