HI all
I have seen Hippo has placed a MMU system in the Wiki. Just for playing, I have tried to compile a kernel for it. When including MMU support, compilation barfs at fork.c (as it did in the past). When not including MMU support, kernel image doesn't boot. I don't need MMU support in my design but I would like to know what is its current status TIALink Copied
The MMU-enabled NIOS needs a new gcc (which is a gcc4) and thus a new toolchain. Same has been created by WindRiver on account of Altera and is not publicly launched to Open Source yet. Unless you have an NDA with Altera, you will not be able to compile anything for a NIOS-MMU CPU.
-Michael- Mark as New
The MMU-enabled NIOS needs a new gcc (which is a gcc4) and thus a new toolchain. Same is created by WindRiver and not publicly launched to Open Source yet. Unless you have an NDA with Altera, you will not be able to compile anything for a NIOS-MMU CPU.
-Michael
