While following those instructions on "philip pemberton's website" (Installing Altera Quartus 10 Web Edition on Ubuntu 10.04), everything goes fine with Quartus and USB programmer tricks on Ubuntu 10.04LTS 32bit. ModelsSIM installation returns the following output:x@y:~/somedir$ sudo sh ./setup
./setup: 1: Syntax error: "&" unexpected On SuSE 11.3 64bit with additional tweaks i can install everything. This is with Quartus/MS 10.0 version. I have no idea what might be the cause of this error or how to find it. Any help appreciated.Link Copied
Problem solved. I confused sh with bash.
Hi
Could you explain in details the way to run this setup? I have the same problem on Ubuntu, and I found no information about solving it.- Mark as New
I'm not sure what exact details did you mean.
If you're talking about the exactly same problem, i typed sh where bash was needed. That is, line: x@y:~/somedir$ sudo sh ./setup Should look like this (as written in philp's site): x@y:~/somedir$ sudo bash ./setup
Therewere someother minor problems with quartus on 64bit SuSE.Good luck.
this was exactly, what I needed.
I didn't get it, just to simply switch sh/bash in command line. Thanks a lot!
