- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Now, I'm spending over two weeks on VIC and it doesn't work as expected.
This is a serious problem for me, my bachelor thesis will end in less than 4 weeks. I read all threads, containing "vic" or "vector interrupt controller" in this forum. I read a lot of altera literature: - AN595: Vectored Interrupt Controller Usage and Applications - 8. Exception Handling - Creating Multiprocessor Nios II Systems - Nios II Embedded Design Suite Release Notes and Errata - Instantiating the Nios II Processor in SOPC Builder Inspected the AN595 and nios ii multiprocessor design example (http://www.altera.com.cn/support/examples/nios2/exm-multi-nios2-hardware.html) examples and it is still not working. Where is the mistake ? software environment: Quartus II and Nios II IDE SBT v9.1sp2 system environment: 3 CPUs, shared memory data exchange sopc-overview (http://img801.imageshack.us/img801/8787/pic1i.png) sopc-overview (http://img576.imageshack.us/img576/6202/pic2pd.png) sopc-nios ii -> advanced features (http://img256.imageshack.us/img256/8326/pic3y.png) sopc-inthand (http://img841.imageshack.us/img841/9891/pic4a.png) use-case: cpu1 writes in cpu1_IntGen pio which is connected with cpu2_IntHand pio. cpu2_IntHand triggers on rising and falling edges, creating an interrupt request. This is done 10x times, with 50 ms delay. I tested this use case on systems without a vector interrupt controller. All fine! (One project each for cpu1 and cpu2. Then "Debug As" both projects) code: cpu1
void task1(void* pdata)
int i;
for(i=0; i<5; i++) {
IOWR(PIO_PIN_OUT_BASE, 0, 0xff);
IOWR_ALTERA_AVALON_PIO_DATA(CPU1_INTGEN_BASE, 0x1);
OSTimeDlyHMSM(0, 0, 0, 50);
IOWR_ALTERA_AVALON_PIO_DATA(CPU1_INTGEN_BASE, 0x0);
printf("Sender finished");
cpu2
int main()
printf("Starting internal interrupt roundtrip performance test.\n");
interrupt_watch_value = 0;
timer_interrupt_latency_init ((void *)CPU2_INTHAND_BASE,CPU2_INTHAND_IRQ_INTERRUPT_CONTROLLER_ID,CPU2_INTHAND_IRQ);
printf("%d\n", &timer_interrupt_latency_irq);
while (interrupt_watch_value < 10) {
/* wait for interrupt */
printf("Interrupt occured");
printf("\nSending EOT to force an exit.%c",EOT);
return 0;
// ISR INIT
void timer_interrupt_latency_init (void* base, alt_u32 irq_controller_id, alt_u32 irq)
/* Register the interrupt */
alt_ic_isr_register(irq_controller_id, irq, timer_interrupt_latency_irq, base, NULL);
/* Enable CPU2 interrupts (PIN1) */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(CPU2_INTHAND_BASE, 0x2);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(CPU2_INTHAND_BASE, 0x2);
// ISR
void timer_interrupt_latency_irq (void* base)
IOWR(PIO_PIN_OUT_BASE, 0, 0x0); //set to low, stop DigiView timing analyzing
/*Stop timer */
interrupt_watch_value += 1;
problem: In debug mode, there is no output when more than one cpu is used (simple texts with printf). Alone, when only one cpu is used, all fine ! Even sometimes, an interrupt request is processed, but only once. Why ? I appreciate any comment, thanks. Regards, R2-D2
Link copiado
0 Respostas
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
