NIOS II/F With No JTAG
Hi all,
I have a NIOS II/F design which has level 2 debug with JTAG UART.
We want to remove it for various reasons now our production devices can load its own code from ROM.
However, if I cange the debug level to 'no debug' in SOPC builder I get the error
"cpu: Unknown Break Location CPU/JTAG_DEBUG_MODULE"
The problem is I can't change that location in the 'more CPU settings' tab, so I cant clear the error and generate the design!
Any ideas on how to remove the JTAG uart?
[I'm using Quartus 6 and SOPC builder 6 Build 178]
TIA
Tom
I have the same problem, I have a Nios processor and DDR interface inside a EP2C8Q208 chip and I would like to remove all unnecessary stuff to be able to speed up the processor to >85MHz to make it the same as the DDR clock.
Another thing is that the jtag_debug_module consumes two M4K blocks that I could use for processor cache.
there is a solution in the Nios errata, just remove the cpu and add a new without the debugger
http://www.altera.com/literature/es/es_nios2eds_60.pdf (http://www.altera.com/literature/es/es_nios2eds_60.pdf)
Excellent http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thanks for the info!
