Do we need to purchase any license for NIOS II gen2 economy/fast cores?
No license is needed for using NIOS tool but you must have a license to the Nios II IP core or a development kit to generate an FPGA programming file and flash programming files.
However, you do need a license for NIOS ll/f and IP will be in floating if you are using floating license:
Topic Options
