12606 Discussions
NicheStack can't initialize the PHY
Good day.
I have a problem with NicheStack and a PHY.
I am using the 3sl150 Stratix III based devkit. As I am a beginner, I am using NIOS II standard design that comes with the board. As I tried to launch the Simple Socket Server (SSS) application, it could not allocate the PHY (the board's PHY is Marvell 88E1111 that is supported by the driver by default, as it is written in the documentation) and came up with the error:
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x00001400
ERROR : MAC Group[0] - No PHY connected!
ERROR : PHY[0.0] - No PHY connected! Speed = 100, Duplex = Full
OK, x=401, CMD_CONFIG=0x00000000
The design uses Triple Speed Ethernet in RGMII mode for networking.
There are no other MAC interfaces (like lan91c111) in the design.
What can be wrong?
Is the PHY actually responding? Try to capture the MDIO signals with signaltap and check if it is answering the MAC.
Thanks, I''ll try..
Finally.. Everything seems to be OK.
If anyone has the problem with networking on 3sl150, please, check this out. This will help.
http://www.alteraforum.com/forum/showthread.php?p=86569#post86569
VOvsi
Hello, I had the same problem
(INFO : TSE MAC 0 found at address 0x00103000
ERROR : PHY[0.0] - No PHY connected! Speed = 100, Duplex = Full OK, x=401, CMD_CONFIG=0x00000000 ), and the link you gave is not valid. Could you help me?
Liuqian
Have you solved the problem?Can you communicate me by email aranaagrail@outlook.com
ntahoturi5922
I am having the same issue and I signal taped the MDIO and MDC and they show connected fine. RX_CLK is fine but not getting anything on the TX_CLK.
IF anyone can share how solve this issue, It would be greatly appreciated.
