Hi all.
I tried to enter debugger and check about r/w to memory. First of all i can not Resume to breakpoint (Resume button not availiable). Second ,i can not see memory data. I have error "Unable to get memory block". What wrong ?Everything looks O.K. in terminal window: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Thanks at advance. AlexLink Copied
