I have to connect a Nios2 with a PC on which there's WINXP OS
I cannot use any OS for Nios2 and so I'll use the RAW Api of LWIP. The question is.... Can I use a telnet client to send and recieve strings? Do I have to use LWIP also on my PC? or can I use windows sockets? Thank you allLink Copied
You can use ordinary windows sockets
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
Hi, i am a c/c++ programmer, sorry but i don't know nothing about fpga programming but i have to estabilish a connection whith an fpga which does the server side. I have a great problem: standard socket blocking recv functions in c return 0 only if the connection is closed by the remote side. I've noticed that often the fpga makes my recv function returns with 0 value even if non one forces the disconnection. Does someone could exlpain it? Have i to use different functions? Thanks to all (even for the patience)!!
