12620 Discussions
Problem in using Avalon_Tristate_slave...
I am currently using " Altera Stratix 1S10 Development Kit".
In SOPC Builder, I wanted to connect my User Logic to Nios Processor through Avalon_Tristate_slave.
The Entity Interface in VHDL code of my User logic [Inverter]is:
entity pipeline is
Port ( clk : in std_logic;
reset : in std_logic;
cs : in std_logic; -- chipselect
wr : in std_logic; -- write
rd : in std_logic; -- read
Outen : in std_logic; -- outputenable
dio : inout std_logic_vector(31 downto 0)); -- Data Bidirectional
end pipeline;
Here, I tried to add this New Component in SOPC builder.
While editing the componet by "Component Editor" wizard, I have chosen Avalon_tristate_slave_0 in Interface-Tab.
Then in Signals Tab, Signal type option for this bidirection signal: " dio" is not indicating the type "Data". So by this, the Component is NOT Set as "OK" by Editor. So I am unable to proceed.
I have gone through the document "mnl_avalon_spec.pdf", there I found this is the minimum requirement of signals to be done, for Tristate Bus Interface.
Then What would be the problem, Can anyone help me out??
K V Naresh
You don't always need the tri-state bus.
The tri-state bus is needed mostly when you want to share pins with cfi flash or sdram.
eg, smc91111.
It is easier to build the component without avalon tri-state bus, and make your io port data bus tri-state with logic.
eg, lcd or many others on DE2 board.
--- Quote Start ---
originally posted by hippo@Jun 6 2006, 06:45 AM
you don't always need the tri-state bus.
the tri-state bus is needed mostly when you want to share pins with cfi flash or sdram.
eg, smc91111.
it is easier to build the component without avalon tri-state bus, and make your io port data bus tri-state with logic.
eg, lcd  or many others on de2 board.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15941)
--- quote end ---
--- Quote End ---
hi
be carefull with "inout" use inside an FPGA, it&#39;s easier to use to bus one "in" and the other "out" and multiplexe them.
for I/O pins there is no problem to use "inout", but with an internal signal ... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
best regards
I read your e-mail.
Is your user login on the fpga or on another chip?
You cannot use tri-state bus inside the fpga.
An outside tri-state bus won&#39;t speed up anything.
The avalon bus is not traditional microprocessor bus. It uses slave-side arbitration. So different masters can access different slaves at the same time.
You should re-design your arch.
You should use dma to transfer data to/from your user logic.
Either use the dma core or build your own.
If is very slow to let CPU move the data.
You should try to use dsp builder, custom instruction or other hardware approach to process your data.
The ethernet driver is slow. you can search on the forum to find some ways to speed up.
Hi Hippo,
To use this Burst mode of Transfer,
How to connect my User Logic in Burst mode. In Component Editor, I could not find any option related to this. In Altera-Literature, that I have, I could not find it.
Can you please help me out!!
K V Naresh
--- Quote Start ---
originally posted by hippo@Jun 6 2006, 06:32 PM
is your user login on the fpga or on another chip?
--- Quote End ---
I am working on " Altera Stratix 1S10 Development Kit" alone. My entire architecture is on this board only. I am not using any other chips.
My User Logic is in FPGA - EP1S10F780C6 only.
K V Naresh
Did you read the quartus II v6.0 handbook vol.4 avalon switch fabric ?
And Avalon Interface Specification .
Hi Hippo,
I have gone through those two documents ( Avalon Interface Spec & Avalon Switch Fabric) few weeks back.
This Avalon Interface Spec document explains about the behaviour of Burst Transfer & its timing waveforms, but the procedure to enable Burst Transfer in SOPC Builder is not given in these documents.
I have with me Quartus-5.1 now, It supports Burst mode of communication. right?
K V Naresh
You should update to v6.0 .
The component editor is for simple component. It is not possible to handle all complex construct. (or too costly to develope the software)
You have to do it with an text editor.
For your project, using CPU to access a burst slave won&#39;t get any gain in speed.
You must use DMA , either the standard avalon DMA or costom designed DMA.
You don&#39;t really need burst.
You shall start with a simple component, with two slave ports.
One port s1 for output (from the view of CPU), and the other port s2 for input.
s1--> user logic --> s2
slave s1 pins: s1_writedata,s1_write,s1_waitrequest
slave s2 pins: s2_readdata,s2_read,s2_waitrequest
waitrequests are used for synchronize.
Then the component can be accessed by CPU or DMA.
