Hello to everyone.. i am having trouble to put a nommu uCLinux on my DE2 Board
I've be trying for a week now without sucess. All i did was use the DE2/DE_NIOS_HOST_MOUSE_VGA demonstration as a template. Then i set my exception and reset_vector to sdram_0 (8mb) I can make the image without anyproblems and also download to the board but when i type nios2-terminal nothing happens my adress map is attached to this thread.. please give me a hand =)] My SOPC is also attached# nios2-download -g /home/aprado/LinuxFPGA/NOMMU/nios2-linux/uClinux-dist/images/zImage
Using cable "USB-Blaster ", device 1, instance 0x00
Processor is already paused
Initializing CPU cache (if present)
OK
Downloaded 1345KB in 11.8s (113.9KB/s)
Verified OK
Starting processor at address 0x00500000
# nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster ", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
and nothing happens...
