12746 Discussions
Quartus Programmer Command-Line Problem
I try to configure the FPGA via NiosII Shell (NiosII 1.1) and Quartus Programmer using the following line:
[SOPC Builder]$ quartus_pgm --cable="USB-Blaster [USB-0]" --mode=jtag --operation=p;test.pof
The line looks correct for me but I get an error message:
Error: Programming option string "p" is illegal. Refer to --help for legal programming option formats.
Any idea, why the option p for programming is wrong?!?!?!?
damc
try this:
Nios-sof --cable=&#39;USB-Blaster [USB-0]&#39; <path and file name you want to download>
Make sure to use forward slashes for your path and file name. This will in turn make a call to the Quartus programmer, but make sure you are programming the .sof and not the .pof file.
Thanks BadOmen,
didn&#39;t knew nios-sof.
Damc
You&#39;re welcome.
I think that command is left over from the Nios I days (otherwise it would be called Nios2-sof).
Using nios-sof is often easier.
But just for reference, I think your problem with the command line is that you put a semicolon into the arguments. Under shells such as bash this is a command separator. If you escape the semicolon with \ or put quotes around that argument then it should work.
