I need to have DSP kit having following specs.
1GB Ram(Max) Ports: 485 * 2 & 422 Ethernet * 2 Port :232* 2 Serial to USB Converter (1 MB Support) Battery Supported Touch Screen Compatibility (Having VGA or HDMA Jack) Linux & Android Compatible Please give me feedback in this aspect.Link Copied
I don't know any Altera kit that can run Android. You'll probably have to try and put an ARM but it won't be an easy task. You'll probably have better chance with a hardcore ARM board instead of a kit from Altera.
