12745 Discussions
Running Hello Word example from Nios II SDK Shell
Hi all...
How can I run the "Hello Nios II" example from Nios II SDK Shell ?
I tried to use these comands:
$ nios2-elf-gcc -o hello.o hello.c $ nios2-elf-gcc -nostartfiles -g -nostdlib -Wl,--gc-sections -Wl,-static -mhw-mul -mhw-mulx -mno-hw-div -o hello hello.o $ elf2flash --silent --input=hello --flash=U5 --boot=`$QUARTUS_ROOTDIR/sopc_builder/bin/find_sopc_component_dir altera_nios2`/boot_loader_cfi.srec --outfile=./hello.flash --sim_optimize=0 --base=0x00000000 --end=0x007fffff --reset=0x00000000 $ nios2-flash-programmer --input=./hello.flash --sof=`$QUARTUS_ROOTDIR/sopc_builder/bin/find_sopc_component_dir altera_nios_dev_board_stratix_1s10_es`/system/altera_nios_dev_board_stratix_1s10_es.sof --device=1 --base=0x00800000 20/10/2005 11:47:26 - (INFO) nios2-flash-programmer: Launching Quartus Programme r to download:     c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es/syste m/altera_nios_dev_board_stratix_1s10_es.sof Pre-Reading 35KBytes of data from U5:    |----.----+----.----|    ********************* (2.641 sec). 20/10/2005 11:47:47 - (INFO) nios2-flash-programmer: Success.  Zero bytes writte n to U5-     (because device matched contents of ./hello.flash) 20/10/2005 11:47:47 - (INFO) nios2-flash-programmer: Flash programming complete
There are no errors from these commands... But I couldn't get the "Hello from Nios II!" message in nios2-terminal.
What is wrong?
Maikon.
--- Quote Start ---
originally posted by maikon@Oct 20 2005, 09:10 AM
hi all...
how can i run the "hello nios ii" example from nios ii sdk shell ?
i tried to use these comands:
$ nios2-elf-gcc -o hello.o hello.c $ nios2-elf-gcc -nostartfiles -g -nostdlib -wl,--gc-sections -wl,-static -mhw-mul -mhw-mulx -mno-hw-div -o hello hello.o $ elf2flash --silent --input=hello --flash=u5 --boot=`$quartus_rootdir/sopc_builder/bin/find_sopc_component_dir altera_nios2`/boot_loader_cfi.srec --outfile=./hello.flash --sim_optimize=0 --base=0x00000000 --end=0x007fffff --reset=0x00000000 $ nios2-flash-programmer --input=./hello.flash --sof=`$quartus_rootdir/sopc_builder/bin/find_sopc_component_dir altera_nios_dev_board_stratix_1s10_es`/system/altera_nios_dev_board_stratix_1s10_es.sof --device=1 --base=0x00800000 20/10/2005 11:47:26 - (info) nios2-flash-programmer: launching quartus programme r to download:     c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es/syste m/altera_nios_dev_board_stratix_1s10_es.sof pre-reading 35kbytes of data from u5:    |----.----+----.----|    ********************* (2.641 sec). 20/10/2005 11:47:47 - (info) nios2-flash-programmer: success.  zero bytes writte n to u5-     (because device matched contents of ./hello.flash) 20/10/2005 11:47:47 - (info) nios2-flash-programmer: flash programming complete
there are no errors from these commands... but i couldn't get the "hello from nios ii!" message in nios2-terminal.
what is wrong?
thanks,
maikon.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10480)</div>
--- Quote End ---
I think your uart has some problem,i am sorry i can not write in english very well.
