SOPC builder
Hi to all,
it&#39;s very strange the SOPC builder&#39;s behaviour in QII 6.0, in fact if I try to create a new component (previously simulated alone), SOPC gives the error number 3 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif , this I think because my component uses modules inside other files (or libraries), in the contrary, if I include all the requested modules inside the file of the component I want to instantiate in SOPC builder, everything works well http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif .
Can anyone explain this strange behaviour?
I have the same problem with QII 5.1 SP2.01
I try to create a new component in SOPC Builder (open cores uart16550)
I put all verilog files in a directory under the quartus project directory
/src/uart16550
raminfr.v
timescale.v
uart_debug_if.v
uart_defines.v
uart_receiver.v
uart_regs.v
uart_rfifo.v
uart_sync_flops.v
uart_tfifo.v
uart_top.v
uart_transmitter.v
uart_wb.v
I start component editor and add all the above hdl files, it starts green blinking,
2 files are ok then error occures
Error: command "quartus_map --generate_hdl_interface=C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v ce_temp_directory/ce_temp_quartus_project" returned 3
Error (10054): Verilog HDL Compiler Directive error at uart_debug_if.v(90): can&#39;t open Verilog Design File "uart_defines.v" File: C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v Line: 90
Error (10112): Ignored module "uart_debug_if" at uart_debug_if.v(92) due to previous errors File: C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v Line: 92
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
Error: Processing ended: Tue Jul 25 20:03:15 2006
Error: Elapsed time: 00:00:01
Error: C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v.xml does not exist
after all errors I cannot select uart_top as top level module
can someone please help me because I only know vhdl and not much verilog,
has anybody already created this uart in sopc builder ?
thanks
I tried to do in your way, but, of course doesn&#39;t work.
I think the only chance you have is to create a single file with everything inside.
